North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   Tires, Wheels, & Brakes (https://www.northamericanmotoring.com/forums/tires-wheels-and-brakes-36/)
-   -   Worries about rubbing with 215/45/17's? (https://www.northamericanmotoring.com/forums/tires-wheels-and-brakes/40671-worries-about-rubbing-with-215-45-17s.html)
erik99 Apr 5, 2005 12:07 PM
This is on a stock '05 MCS. Should I be worried that the 215's will rub with this set up? Again I ordered Rota Grids 17" x 7.5", +45 offset wheels with 215/45/17 Yokohama ES100's
The guys at RSpeed (ordered from them) said I should have no rubbing issues. But after reading some threads here I am second guessing the 215 width :confused:
Thanks!
minimort Apr 5, 2005 12:35 PM
I have Proxes FZ4 in 215/45 on my S-lites, no rubbing at all and rides nice, not sure about with the +45 offset though
erik99 Apr 5, 2005 12:44 PM
From what I've read, the 17" x 7" wheels use a 42mm offset and the 17" x 7.5" use 45mm.After reading more of the "Show me your wheels" thread it seems the size I selected is OK.
MyPocketRocket Apr 5, 2005 12:53 PM
Did you lower the car? If so it will rub.
I have used the M7 springs with 205/45/17 with no problem, but after I changed to AVS100 215/45/17 with ASA AR1 42 offset I can hear the rubbing noise coming from the back. I trimed the plastic wheel wall off and no problem ever since.
Rick-Anderson Apr 5, 2005 01:04 PM
I am running 42m offset 17x8 with M7 springs and it rubs pretty bad. But I think it is due to the width and offset of the wheel more than the tires. BTW, the ride quality is awesome.
MyPocketRocket Apr 5, 2005 01:18 PM
Yes, you're running 17x8 that's why. For me 17x7 with M7 springs before the trim is not that bad...almost no rubbing. They only rub over bumps.
erik99 Apr 5, 2005 03:29 PM
I'm completely stock now. I may change the order to 205/45 just to be safe. I don't want to blow a hole through my wheel wells during the Dragon.
kazlot Apr 5, 2005 05:27 PM
Rubbing with 215/45/17's
I run Yoko AVS sport 215/45/17's on 17x7 +45 offset (Team Dynamics) on my stock 03 MCS without rubbing.
Yoko ES100 may rub because the edge is more square than the AVS sport.
You might want to try a more rounded edge tire like the AVS sport, although a bit pricey.
Another good choice would be the Goodyear Eagle F1 GS-D3 which is less money and a better tire in the wet.
I did not had any rubbing problems when I went to Laguna Seca for a track day.
If there is any rubbing it would be very very little with the AVS sport or Eagle.
Hope this helps...
wkndracr Apr 5, 2005 05:28 PM
You should be fine based on what I've seen on the board. I just ordered a set of 17x7.5 +42 offset with 215/45/17.
rcoopers Apr 5, 2005 10:07 PM
you should have no problem i am running 215/45/17 goodyear f1 on s-lites i have driven the car relatively spirited since i had them put on without no tire rub at all and i do have h-sport springs on my S ....you should be ok...:thumbsup:
minihune Apr 5, 2005 11:34 PM
erik99,
You should trust the guys at Rspeed. You're fine.
The stock MCS can use without problems any 17x7 or 17x7.5" rim with wheel offset from +37mm to +50mm and tires up to about 25" outer tire diameter.
Even those with a square shoulder like the Yokohama AVS ES100.
Adding a rear swaybar doesn't affect any wheel or tire combo.
The minute you drop your MINI using lowering springs or coil overs you decrease clearance and have to watch out for:
Rim width such as 8" or wider
Large diameter tires of stock size or greater than 24.6"
Wide tires of 225mm (usually the limit on width without trimming)
Wheel offset (usually look for +42mm to +48mm for 17" rims)
onasled Apr 6, 2005 04:19 AM
Kosei K1, 17x7.5 with avs100 215/45/17 and lowered with H-Sports. I have had to trim back both plastic and metal in the rear wells and a bit of the flair's inner lip on the fronts because of rubbing, and I can still rub.
All Minis are NOT the same, so it's a roll of the dice when going wider. I think if I put another .3 degree of neg camber in the rear, I'll be OK.
minihune Apr 6, 2005 04:40 AM
I've used 17x7" rims with +42mm offset, H-sport springs (1" drop) and Yokohama AVS ES100 tires in 215/45-17 and got rubbing in both rear wheel wells. Nothing serious just when loaded down with four people or on very bumpy roads at about 50+ mph. I didn't trim, just drove it for two years and the plastic rubbed down by itself with the same effect as trimming with a dremmel. Switching to Bridgestone Potenza S-03s in the same size didn't help, still rubs.
Before you change your rear camber to more negative just remember-
More rear negative camber increases understeer, wears the inner side of the rear wheels more, and doesn't help straight line performance. Everything you adjust in suspension has an effect and cost. Take the middle road when you can.
MyPocketRocket Apr 6, 2005 06:35 AM
Don't worry just get what you want. I knew that 215 and lower springs will rub, but I get them anyway. :razz:
erik99 Apr 6, 2005 06:52 AM
Well, one of my concerns with rubbing has to do with SCCA Solo II rules. IIRC, you cannot have a hole rubbed through your wheel well liners in Stock or STS class. Also, I may want to lower the car in the future....we'll see how things go in G Stock first.
I've got a call into RSpeed. I'll keep you posted.
erik99 Apr 6, 2005 08:58 AM
I talked to Joseph at RSpeed. He thinks the 215 may rub with stock suspension. He also thought 205 would look better on a car that isn't lowered. We changed the order to 205's.
This is why I'm glad to be dealing with a local MINI shop :thumbsup:
MiniMargie Apr 12, 2005 05:27 AM
215/45 Bridgestone RE-92's on 17x7 with ET42 - no issues at all. :thumbsup:
erik99 Apr 12, 2005 06:26 AM
The engineer in me won and I went with 16X7 Rota Grids shod with 205/50/16 Yoko ES100.
I'll whore out the set up here too :wink:
http://usera.imagecave.com/erik99/wh..._wheels003.jpg
http://usera.imagecave.com/erik99/wh..._wheels005.jpg
JeffS Apr 12, 2005 08:47 AM
215/45/17 here with 17x7 +37 OZ Superleggeras. Running H&R springs.
I have no rubbing issues, though I've not added rear control arms to reduce the negative camber in the rear.
It is important to pay attention to both wheel width and offset. A 7.5" wheel will change the effective offset of a wheel by 6.35mm.
For example:
17x7 +38 will be about the same as
17x7.5 +44
Of course, I'm ignoring the fact that the wider wheel will stretch the tire slightly, changing the shape, but as far as clearance goes, the effect is somewhat minimal.
caminifan Apr 12, 2005 09:31 PM
Hmmm, now I am wondering if I am setting myself up for problems. I am considering BBS RG-F in 16x7 (+35mm offset) or SSR Competition in 16x7 (+42mm offset) with Michelin Pilot Sport A/S tires in 205/55-16 size. I am also considering the H-Sport progressive lowering springs (.5 inch lowering). The Michelins are spec'd at a 25.2 inch diameter on TireRack.com. Am I going to run into rubbing problems with this combination? Should I go with the BBS RG-F based on the more conservative offset? The car is an MCSa that is on order.
JeffS Apr 12, 2005 09:55 PM
Maybe people should be more specific with regards to where the tire is rubbing.
I'm new to Mini's so I don't know where the trouble spot is. With other cars, the problem tends to be on the outside - in which case, the +35 would only increase the chance of problems.
I have heard of mini owners rubbing various parts on the inside though so maybe that's the primary problem?
Yet another thing to keep in mind is spring rate and swaybar size. I'm running a large rear bar which could be controlling any rubbing tendencies my setup might have. From my own experience with the 215's on 17x7 +37, I would move close to +40 with my next set of wheels simply because I feel like I may have issues when I add positive camber back to the rear of the car. Hopefully I won't be trading one potential problem for another.
I suppose the safe bet is to just run 205's on the street. That's what I'll be going back to. My primary concern is fitting 225's for the track.
