Best tire for week long track event, skid pads, OLOA ?
Old Jan 25, 2005 | 09:03 PM
red rage's Avatar
red rage
ALex and tire-track buffs,
My car, myself and a famous MINI tuner will be embarking on the Onelap of America this year
We need to know which tire will be "the tire" to drive on for this week long, 3,500 mile event which includes 8 tracks, we will runa 215-40-17 size
I saw the Tire-Rack spread sheet here:
http://www.tirerack.com/a.jsp?a=EZ3&url=/tires/surveyresults/surveydisplay.jsp&type=MP
But also noticed that the winner of the wet-skid pad and dry skid-pad events had different tires too
Phil
Last edited by Alex@tirerack; Jan 26, 2005 at 07:42 AM. Reason: added tracking inforation, giving NAM more click thru credit!
Old Jan 25, 2005 | 10:10 PM
Ryephile's Avatar
Ryephile
Since you've narrowed down the tire selection via tire size; I'd pick the Goodyear GS-D3 as the best all-around tire.
Old Jan 26, 2005 | 07:59 AM
Alex@tirerack's Avatar
Alex@tirerack
Goodyear D-3, or Bridgestone S-03 Pole position
Alex
Old Jan 26, 2005 | 08:04 AM
ChiliBit's Avatar
ChiliBit
Borrowed Proxes T1s
Old Jan 26, 2005 | 04:02 PM
red rage's Avatar
red rage
Thanks for the info ...
Old Jan 26, 2005 | 05:14 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Alex
No matter which of these two you choose (both are good), do keep checking your tire pressures and for irregular wear. You can adjust each day for track conditions.
Mark the tires for wear with a chaulk or white shoe polish. Better yet, use a tire pyrometer probe to maintain even temperatures across the tire tread from inside to outside. If too hot in the middle tread then your psi is too high. Adjust by 2 psi.
Also you can rotate tires even if they are directional (right tires rotate only front to rear) to help them last a little longer.
In the MINI the rear tires don't heat up as much (about 20 to 30 degree less on the track) while the front tires wear quickly depending on the course and your driving tendencies.
Also make sure that your brake pads are good and maybe upgrade your brake fluid to ATE super blue or similar (higher boiling point than stock fluid).
M7Speed
Aug 10, 2015 01:13 PM
M7Speed
R61 :: Paceman Talk
Aug 10, 2015 01:01 PM
M7Speed
Aug 10, 2015 01:00 PM
M7Speed
R55 :: Clubman Talk (2008+)
Aug 10, 2015 12:58 PM
