Stock 2010 MCS R56 17" max offset
Old Feb 27, 2020 | 03:41 AM
Stylo Bic's Avatar
Stylo Bic
Hey guys,
My original wheels are corroded, and it's been too long now that i'm looingk for 17x7 or 7.5 aftermarket wheels for my R56 MCS.
i really like BBS style rims, but most of the time they come in a 35 offset, like the JUNK https://www.wheelbasealloys.com/allo...back/2007-2013
which max offset I can go without facing any pb ?
Old Feb 28, 2020 | 07:13 PM
Stylo Bic's Avatar
Stylo Bic
hello ?
Old Feb 28, 2020 | 09:25 PM
Teabudy's Avatar
Teabudy
I'm curious as well. Seems kinda dead in wheels n tires tho
Old Mar 1, 2020 | 09:47 AM
Stylo Bic's Avatar
Stylo Bic
seems you're the only one to be curious...
I also found DARE wheels https://www.daremotorsport.com/cast-...silver-rivets/
Maybe someone could give his opinion on BBS replica wheels, which brand to go ?
Old Mar 1, 2020 | 08:47 PM
LostbutFound's Avatar
LostbutFound
My guess is everyone is hoping you will do a search. There are threads on here that cover this subject in great detail. IF I remember correctly 35 is about max for a 7 inch wheel.
Old Mar 1, 2020 | 09:27 PM
Stylo Bic's Avatar
Stylo Bic
the search was done, but too many post to read. At least you had nothing to say but you bumped my thread, so thank's anyway
Old Mar 24, 2020 | 10:51 PM
thebmwnut's Avatar
thebmwnut
It's late and I have screwed my post up twice so I will give you the short version. I run a 17x8 with 35mm offset with a 215 wide tire and feel that's the max without any real issues. If you have a 7 or 7.5 width wheel with the same 35mm offset then you will have more clearance then mine. 0.5 inch is 12.7mm . With the math then a 7.5 width wheel will have 6.35mm better clearance and a 7 inch wide will have the full 12.7mm better clearance then mine. Hope this helps.
Old Mar 24, 2020 | 11:14 PM
thebmwnut's Avatar
thebmwnut
my mini with 17x8 35mm offset and 215 45 17 tires
Suprememrvn
Tires, Wheels, & Brakes
Feb 2, 2018 05:31 AM
mini4tide
Nov 18, 2011 08:41 AM
PERNOR56
Dec 6, 2008 03:59 PM
Scoobywrx
SCCA Solo and ProSolo
Jun 25, 2007 09:08 AM
Aeromax
May 9, 2007 06:34 AM
