205/45 vs 205/50 tyre option considerations
Old Sep 26, 2019 | 03:03 AM
json's Avatar
json
My stock '09 JCW comes with the standard R112 rims and 205/45 R17 tyres.
Recently, I ve decided to try out the Neova AD08R, but due to EU environmental restrictions, it was discontinued and replaced by AD08RS. The newer, environmental-friendly version of the road-legal 'semi', isn't as good as the older AD08R (according to reliable sources).
I can't find the 205/45 of the AD08R in stock anymore and the only option seems to be new AD08RS.
However I can still find the AD08R in 205/50. But would that be a good choice to make? Car is mostly used on road (spirited driving occasionally) and occasional track use. Personally, I am not bothered about the speedo/km meter reading deviation that would result from that thicker tyre. Also, I am not bothered about the goofy looks of the thicker tire on the car. My only concern is how it behave on the road (and track) and, of course, safety.
Given the above priorities, is the 205/50 still applicable, or should I stick with the MINI endorsed 205/45 and go for the slightly inferior AD08RS?
Any input will be appreciated from people that have extensive enperience on the 205/50 tyre on their JCW or S.
Thank you!
Old Oct 1, 2019 | 08:05 AM
Jaywills's Avatar
Jaywills
You might consider
A set of 215/17-45's if your brand comes in that size. Just swapped out a set of 205's for the 215's and they work well. Tread width up ~ 5%. Plus, in the 45 size, your indicated speed is ~ less than 1 mph different from your actual speed. Good luck.
Btwyx
Tires, Wheels, & Brakes
33
Nov 27, 2012 02:48 PM
gokaht
May 12, 2008 10:54 AM
zack726
16
Dec 11, 2007 07:04 AM
pyugala
Jul 17, 2005 07:38 PM
aVjai
Mar 13, 2003 08:32 PM
