R81’s 15 inch
I want to run 15’s on my 05 MCS but not sure what size I should go with. Stock suspension. 205 55 15 or 205 50 15? Any input will be greatly appreciated. Thanks |
Depends on what you are going to do with the MINI. For autoX, lots of performance 205/50-15 choices out there. For fun fast street 205/55-15 get you back to almost full outside diameter(taller sidewall), but fewer choices. Make sure the tire you want is made in that size and enjoy! I’ve run both in the past on my R50, run only 205/50 for track, autoX and Dragon Slaying. |
Originally Posted by 2nd Driver
(Post 4457016)
I want to run 15’s on my 05 MCS but not sure what size I should go with. Stock suspension. 205 55 15 or 205 50 15? Any input will be greatly appreciated. Thanks What type of driving? Street only, any performance events- track or driving school? Any cold weather, commuting long distance, budget? OEM wheels are 15x5.5" and OEM tires are 175/65-15 which work and fit but tire selection is poor. Aftermarket wheels are commonly 15x7" but tire sizes are best closer to OEM tire diameter of 24.3" which give more accurate odometer and speedometer readings. Small tire sizes like 205/50-15 are OK and tire selection is good but you will get a larger wheel gap and less ground clearance with more risk of hitting front lower lip edge. For street use it is possible to use- 196/60-15 fits 5.5-7" wide rims, perfect for 6" wide rim, tire diam. 24.2" Comes in various all season tires like Grand Touring (good for commuting) or Ultra High Performance AS classes. Not good for Summer tire selection. Taller sidewall gives more comfort but less crisp handling, well suited for bad roads. 205/55-15 fits 5.5-7.5" wide rims, perfect for 6.5" wide rim, tire diam. 23.9" . Has limited tire selection of 3 Ultra High Summer and one UHP All Season tire. https://www.tirerack.com/tires/surve...=true&filter=y Tirerack test report https://www.tirerack.com/tires/tests...y.jsp?ttid=217 These tires are OK for street use |
Thanks for the responses, I’m looking to fill the wheel well, not have too big a gap, I’m running stock suspension. Maybe take it out for autoX, but mostly for show. I like the the look of the R81’s reminds me of the old Porsche phone dial back in the 80’s. |
(Post 4457193)
Thanks for the responses, I’m looking to fill the wheel well, not have too big a gap, I’m running stock suspension. Maybe take it out for autoX, but mostly for show. I like the the look of the R81’s reminds me of the old Porsche phone dial back in the 80’s. Ultra High Performance AS or Grand Touring AS are the tire classes to check first. 195/60-15 is a good tire size that fits your wheel and suspension and gives good tire selection for All Season tires. Since you are doing mostly street driving there are good choices in Grand Touring All Season that provide decent enough handling and very good road manners for daily use- https://www.tirerack.com/tires/surve...=true&filter=y Both good budget tires Yokohama Avid Ascend GT $90 each General Altimax RT43 $81 each https://www.tirerack.com/tires/tests...y.jsp?ttid=237 Solid overall Michelin Premier A/S $131 each, costs more but does everything well Bridgestone Turanza Serenity Plus $112 each, older design, not as good in snow |
