16X9 or 17X9 Fitment: Autocross/Track R56
Old 12-17-2018, 01:42 PM
Dr. Spade's Avatar
Dr. Spade
Dr. Spade is offline
Anyone fit a 16X9 or 17X9 +45 on the R56 S w/o much issue?
I'm running a 215 Federal RSRR on a 17X8 but would like a bit wider rubber. Can't really go wider w/o rolling on sidewalls.
I'd run at least a 225/45 on a 17X9 or a 225/50 on a 16X9. 245 is probably too ambitious.
I also run 15X8s with 225/45 BFG Rivals but the gearing is just too low.
Old 12-18-2018, 08:37 AM
Dr. Spade's Avatar
Dr. Spade
Well I found a ND Miata buddy and I'll test fit his 17X9 +42 this weekend. Will let you guys know how it fits.
Old 12-18-2018, 08:55 AM
njaremka's Avatar
njaremka
njaremka is offline
Alliance Member
Received 1,706 Likes on 1,375 Posts
Define "without much issue"...
You will need a pretty big spacer to run a 17x9 +42 on an R56 - it will contact the strut in the front, and probably be pretty close, if not touching, in the rear. With the spacer needed, you'll be sticking out almost 1.5" past the fender, too.
Old 12-18-2018, 09:26 AM
v10climber's Avatar
v10climber
v10climber is offline
I think a 45 offset would be too high and you'll contact the strut with a 9" wide wheel up front or the trailing arm out back. What's the offset of your 17x8?
Even if you did get a 17x9 to fit I'm not sure that you'd be able to fit anything wider than a 215/205 on it. If you're running the car reasonably low there just isn't that much space in the wheel well. We used to run a 235/40/17 pinched onto a 17x7.5 and it would contact the outer edge of the fender liner and the top of the wheelwell under bumps. If you move to a 15x9 with a stiff enough front spring you can run whatever size tire you want. 245s are no problem. Learn to use 3rd a lot.
Do you have an autocross class you're trying to fit into or something?
Old 12-18-2018, 01:04 PM
Dr. Spade's Avatar
Dr. Spade
I'm on 17X8 +35 or 15X8 effectively +30 to clear rear trailing arm.
So the 17X9 +45 would extend 2.7MM outwards which should be fine. But it's 22.7 less inner clearance. You're right, I probably don't have that kind of space back there, especially on springs/shocks. And then the spacer would make it poke way to far.
For 2018 I was STX. At this point I don't even know what class I want to run.
So maybe better to pinch a 235/40?
Old 12-19-2018, 06:37 AM
v10climber's Avatar
v10climber
Wilcox seems to be enjoying SMF
If it were my car and it wasn't a JCW (with the big brakes) I'd be on a 15x9 up front with the 245 Rival S and 15x8 with 225s out back and deal with the shifting. They don't make a bridgestone in the 235/40/17 so I'm not sure you can get that size in a tire that is sticky enough to be faster than just running the 215/45/17 RE71R. Compound >> Size.
If you don't want to buy new wheels then just run a 215/45/17 setup square and call it good enough.
Unless you've got some really fast STU people locally you might do just fine in STU. Or lobby your local region to keep the mini in STX regionally. Or maybe they have a SM on street tires class.
Old 12-19-2018, 06:44 AM
Dr. Spade's Avatar
Dr. Spade
To be honest I've just been asking local STH people if they don't mind me in their class. So far they've just welcomed me in. It's an S so I may just get the 15X9
+35ish. Last event I ran my 15s I shifted to 3rd on four separate occasions so I'm still hesitant.
If I don't buy any wheels I'll go back to the RE-71 in 215. It's been a while since I've ran them and their still my favorite. But the BFG Rivals seems to wear better, especially on the outer edge (need more front camber).
I'd probably use the 15s with a 225/45 Federal RSRR or 225/50 Toyo R888 for track days. Right now it's opposite; 17s for track (215/40 RSRR) and 15s for autocross (225/45 Rival)
dubfelgenwerks
04-21-2014 01:07 PM
IKevinx27I
10-06-2013 10:08 PM
nckash055
Tires, Wheels, & Brakes
23
01-21-2012 10:48 AM
dL_EVO
18
12-21-2010 06:39 PM
n_wong89
07-05-2010 06:39 PM
Quick Reply: 16X9 or 17X9 Fitment: Autocross/Track R56
