- - Will it fit????
(https://www.northamericanmotoring.com/forums/tires-wheels-and-brakes/333690-will-it-fit.html)
Matthew Miller
11-26-2018 05:51 PM
Will it fit????
I'm looking at buying a set of aftermarket wheels off of 2004 Mini to put on my 2013 Mini Cooper my car currently has the stock 175 60r15 and the new set is 205 60r15 they should fit right???
vetsvette
11-26-2018 07:17 PM
Should. They're both 4X100 bolt pattern and the width shouldn't pose a problem.
11-27-2018 06:34 AM
Yep, unless you are really lowered on the ground or have some spacers.
minihune
11-27-2018 11:06 PM
Originally Posted by Matthew Miller
(Post 4434290)
205/60-15 fit wheels 5.5 to 7.5" wide, perfect for 6" wide rim so they will fit OEM 15x5.5" OK. Tire diameter is slightly tall at 24.7" but no worse than 215/45-17 which MINIs will use.
Stock suspension gives enough clearance so should be fine. Moving to a wider tire size will give more rolling resistance but can give you more rubber touching the road.
Matthew Miller
03-28-2019 06:56 AM
Thanks everyone the wheels & tires fit perfect!!!!!!!
