15x10 6ul on an R53
15x10 6ul on an R53
anyone running 15x10 6ul on an r53?
I am going to bump my fronts only and run staggered, currently I run 15x8 square with 225 re71/rs4 or 205 hoosiers. I'm going to run the 15x8 in the rear and go up to 245 rival S 1.5 up front, and 275 A7's up front depending on the event.
10mm up front so the wheel clears the coilovers, none needed in back but I run 2mm anyway so the wheels have a little breathing room, it's real tight at the trailing arms. I tried to fit r56 trailing arms, no way I could do it without spacers
67morris (08-27-2018)
I want to move to 15X9 6ULs and 225 Rivals up front for this season. I am on swift springs and bilsteins b4. I am currently running 15x8 6ULs with 205 Rivals all around with 5mm spacer in back only.
Do 15x9s with 225s up front really require that much spacing? I know there is no 10mm readily available. My choice is likely a 15mm from Way. However, I feel like there is enough clearance to only use 5mm.
Thanks! Didn't think of ebay. I think these will work well. They are hubcentric without hub centering lip. This way I won't need centering rings.
https://www.ebay.com/itm/2-Hub-Centr...F/191740726519
https://www.ebay.com/itm/2pc-4x100-F...S!-1:rk:4:pf:1
Also, found a set with a hub for the wheel to center on:
https://www.ebay.com/itm/2-10mm-Hubc...Xb2c:rk:9:pf:0
With my R53 using 15x8" wheels et+36 I need a 3mm thin rear spacer to clear my rear lower trailing arm or it scrapes by 1-2mm. This is the minimum but I only do short runs of less than 60 sec. Probably a little more is better for cooling if tracked.
cooper a (02-14-2019)
