xxr 536 wheels
Problem with any 205mm wide tire is that it isn't the best fit for a 16x8" wide rim unless you want a stretch tire look.
For example 205/50-16 fits 5.5-7.5" wide rims, perfect for 6.5" wide rim, tire diameter 24.1"
With any lowered suspension you won't have much clearance with tire sizes larger than OEM 24.3"
Compared to OEM 16" MINI wheel and tire, using 215/45-16 for tire size you will be 9mm further from inner suspension, poke out 47.1mm more and tire diameter will be 21mm smaller.
Hippie
Tires, Wheels, & Brakes
08-28-2010 09:51 PM
ururk
14
09-20-2005 05:48 PM
