spacers on R52?
Old 01-21-2018, 10:28 AM
Ken Garchow's Avatar
Ken Garchow
Ken Garchow is offline
spacers on R52?
want to ask what is thickest spacer you can use on an R52 with stock wheels and not need longer lug bolts and still be hub centric
do u run out bolt length first or hub shoulder
thanks
Old 01-21-2018, 10:57 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Whine not Walnuts is offline
Suggest you post that in the tire and wheel section. I also wonder whether the Tire Rack site is able to address the question by selecting the products you are thinking about.
Old 01-21-2018, 01:59 PM
Ken Garchow
whine
thanks dude, but isn't this the wheel and tire section?
i may be messed up
sorry
Old 01-21-2018, 04:12 PM
Whine not Walnuts
No, I messed up, you are in the right place. I view so many threads sometimes I forget what section I'm in. The whine doesn't help either . . . .
Old 01-21-2018, 09:08 PM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
We've used 5mm, but would still recommend going to longer bolts to be safe
https://www.waymotorworks.com/wmw-5m...l-spacers.html
HOTCHKIS | DDM | CRAVEN | AKRAPOVIC | NM ENGINEERING | MEGAN | FORGE | IE | OS GIKEN | POWERFLEX and more
Old 01-23-2018, 11:09 AM
gsfent's Avatar
gsfent
gsfent is offline
OP
Consider swapping to studs and open ended nuts. Length no longer an issue and changing wheels/tires much easier. I am sure one of the vendors here can hook you up.
Regards,
Jerry
Old 01-23-2018, 01:37 PM
ECSTuning is online now
Received 1,964 Likes on 1,764 Posts
I had them on my R52, get the new wheel bolts with the extended length matched to the spacers. If you track or swapping out wheels all the time, might be better to go with studs with the spacers.
Old 01-23-2018, 02:49 PM
RedAggie03's Avatar
RedAggie03
RedAggie03 is offline
I run 15mm spacers and longer bolts from WMW on my 16" X-84's. It looks great, but the rears *slightly* rub when the suspension is compressed. 13mm or less would probably be fine.
WayMotorWorks (03-07-2018)
Old 01-24-2018, 05:30 AM
Derek86's Avatar
Derek86
Derek86 is offline
Buy wheels with a lower offset.
Old 03-06-2018, 08:42 PM
Ken Garchow
just wanted to mention where i ended up with the spacers on my 2005 R52 with OEM R91 wheels
i am running 10 mm rear hub/wheel centric and 5 mm front non hub/wheel centric (cars hub still catches the wheel and centers it)
with longer bolts front and rear
it gives a nice conservative slightly more aggressive look with no rubbing issues
Old 03-07-2018, 06:18 AM
Congrats, any pictures?
Old 03-07-2018, 07:42 AM
Ken Garchow
ECS i don't think i could take photos that would show the subtle change
Old 03-07-2018, 08:04 AM
Take them straight down from the wheel well or long ways along the car, you can see it.
06-12-2015 01:32 PM
06-12-2015 12:53 PM
Tires, Wheels & Brakes
06-12-2015 12:51 PM
AutoxCoop
03-12-2014 09:39 PM
jls1203
05-12-2008 04:32 PM
Quick Reply: spacers on R52?
