Glue for R83 center caps?
Old Jul 18, 2016 | 05:46 PM
wkearney99's Avatar
wkearney99
I've got a second set of R83 wheels for winter tires on my wife's R57. The center cap popped off one of them, so I ordered some extras from ECS.
There appears to be an adhesive backing on the sticker. Is that sufficient to keep it on there?
There's also a bunch of left over adhesive from the old sticker. What's the recommended solvent to remove that kind of glue? I'd want to avoid anything that'd otherwise wreck the finish on the R83 wheel.
Old Jul 19, 2016 | 10:44 AM
Alex@tirerack's Avatar
Alex@tirerack
I have used Turtle Wax T 529 for adhesive issues with a high degree of success.
Old Jul 22, 2016 | 08:23 AM
Capt_bj's Avatar
Capt_bj
I had one of those caps disappear and ordered a replacement
cleaned up the surface on the wheel and set the new cap with the provided tape ...
it was gone the next day ....
next time I used a lil epoxy and it never moved again . . .
checked the other 3 and easily popped two more off ... I had plenty of epoxy left over . . .
Old Jul 22, 2016 | 12:27 PM
Clean the old stuff off with wd40 on the residue and then a wet cloth and let dry. Peal and stick the new ones. Or you can hit them with a little glue like above. You can see our pics on the link and see the new backing.
https://www.northamericanmotoring.co...er-needed.html
; Part # 36136758687
Old Jul 22, 2016 | 01:12 PM
Capt_bj's Avatar
Capt_bj
there's a number of different wheels for MINI
so the thing to look at is the contact area the tape will have vs what the wheel looks like where you stick it .... and the fact that the cap is not flat either ....
Old Nov 22, 2016 | 08:13 AM
wkearney99's Avatar
wkearney99
To follow up, I used the Turtle Wax product to remove any traces of the old adhesive. Then I attached the new one just using the adhesive on the back. I did this back in the summer, on a warm day. The emblem is still there some months later.
I did order two of them, just in case.
Old Nov 30, 2016 | 06:15 AM
Thanks for the order and the update.
quickcoop
Sep 21, 2018 03:40 PM
heavyJ
May 22, 2016 05:34 PM
wloprete
Apr 15, 2016 12:42 PM
MiniKar
Tires, Wheels, & Brakes
Mar 27, 2016 11:27 PM
