Tires, Wheels & Brakes
Mini Cooper Brake Fluid Pentosin Dot4 Lv 1 Liter
Old Dec 15, 2015 | 04:24 PM
Mini Mania's Avatar
Part No: NMB1065
Your Price $13.95
This is a Special Priced Item
Pentosin Low Viscostiy / Cold Conditions Brake Fluid
Pentosin DOT 4 LV is a special brake fluid of highest DOT 4 performance levels and extremely low viscosity at cold temperatures.
It offers safety against vapor lock; it has excellent resistance to absorbing and retaining water and provides superior corrosion resistance. Pentosin DOT 4 LV Brake Fluid is ideal for all modern vehicles with ESP and ABS. DOT 4 LV can be used in all vehicles that require DOT 4 fluid.
From the Mini Owners Manual:
Brake fluid is hygroscopic, that is, it absorbs moisture from the air over time. In order to ensure the brake system's safety and reliability, change the brake fluid every two years. Brake fluid is toxic and also damages vehicle paintwork. Always store brake fluid in tightly-closed original containers kept well away from the reach of children. Do not spill the brake fluid and do not fill the brake fluid reservoir beyond the MAX mark. The brake fluid could ignite upon contact with hot engine
DunkM
Nov 17, 2015 05:38 PM
modemjunkie
Nov 6, 2015 06:40 AM
buddabounce
Nov 3, 2015 05:47 AM
Oct 29, 2015 11:04 AM
Suspension Products
Oct 29, 2015 10:23 AM
