17x9 4X100/114.3 +20MM?
Old Jul 7, 2014 | 08:37 PM
Lil Munchkin's Avatar
Lil Munchkin
Yes I'm a noob. Just got a 2011 Cooper S about a month ago and loving it. I been looking around the forums ever since I got it and finally decided to join the community. Anyways, is it even possible to fit 17x9 4X100/114.3 +20MM? Also, what does it mean by /114.3 +20MM? Sorry for being such a noob, still learning all this stuff.
Old Jul 8, 2014 | 08:03 AM
v10climber's Avatar
v10climber
The 100/114.3 likely means it's dual-drilled for both bolt patterns. So it'll have holes for both 4x100 and 4x114.3. The mini (r56/r53) uses a 4x100 bolt pattern. As far as fitting a 17x9 et20... If you have to ask it's probably not the fitment for you. It would require a lot of effort and even then questionable as to whether it would fit. 17x8 is a much safer and better documented fitment if you're looking for wide wheels.
Old Jul 8, 2014 | 09:52 AM
Lil Munchkin
Thanks for all the Info. Also It's not that I'm looking for wide wheels in those specifications, it's just that the wheels I want are only that size. They do have 15x8 but I don't want that small of a rim. Yes I like the wide look though and I do want poke. Just haven't fell inlove with any other wheels. The wheels I want are the str 520 17x9. I have read that people have done 17x9 on r56 but they don't really explain how they did and if it's a big pain or not.
Old Jul 8, 2014 | 10:43 AM
v10climber's Avatar
v10climber
I've seen people mention 17x9s on a R56 but I've not actually ever seen one in person of pictures of the fitment. I have to imagine you wouldn't be able to lower the car much and you'd have to run some pretty stretched tires.
Old Jul 8, 2014 | 12:33 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
The OEM MINI wheel is 17x7" offset (et) of +48mm. OEM tire is 205/45-17.
You can use a 17x9" et20 rim but what tire and suspension do you plan to use?
If you use OEM suspension there will be a wheel gap, a smaller tire diameter tire size like 205/40-17 or 215/40-17 will increase this gap while a taller tire like 225/45-17 will be tight to fit due to it's wide tread width on a very wide wheel.
For looks, many owners will install fully adjustable coilovers. You can adjust ride height from a small to a large drop.
Using a wide tire that will fit a 17x9" wheel you can consider:
235/40-17 fits 8-9.5" wide wheels, perfect for 8.5", 24 lbs, 24.3" tire diam.
245/40-17 fits 8-9.5" wide wheels, perfect for 8.5", 26 lbs, 24.7" tire diam.
Tire stretch is used partly for looks and adds room for clearance using an extra wide rim with a dropped suspension. Most times the stretched tire will have a smaller tire diameter from being stretch fitted to a wide rim.
Examples of tire sizes for a 17x9" rim stretched:
205/40-17 fits 7-8" wide wheels, perfect for 7.5", 20 lbs, 23.5" tire diam.
205/45-17 fits 6.5-7.5" wide wheels, perfect for 7", 22 lbs, 24.3" tire diam.
215/40-17 fits 7-8.5" wide wheels, perfect for 7.5", 22 lbs, 23.8" tire diam.
215/45-17 fits 7-8" wide wheels, perfect for 7", 23 lbs, 24.7" tire diam.
These tire sizes are all available (with tire weights for each size for comparison) using Yokohama S.Drive (Ultra High Performance Summer tire)
300 treadwear. Tire is suitable for stretching and/or street use.
Before you buy look at examples of how the 17x9 wheel with whatever tire size will fit and look on your MINI.
Here is an R56 Cooper S with 16x9" et25 front and rear with stretched tires.
With that suspension drop, a normal tire size would rub. Using more negative camber and a stretched tire help to tuck the tread areas under the wheel arches. Some removal of the wheel arch plastic using a dremmel tool can also help you gain some clearance. See if you rub then grind away the plastic.
Front negative camber can be increased with adjustable front camber plates, rear camber can be adjusted with rear lower control arms.
By comparison to this picture, a 17x9" et25 wheel would be about 5 mm farther from the inner suspension, and poke out 5mm more (assuming this MINI is not running wheel spacers).
In any event 17x9" et20 wheels can fit with the right tire size.
see post #857 and 858 in-
https://www.northamericanmotoring.co...wheels-22.html
And there are more examples of 17x9 that fit.
If you are going to keep the OEM suspension then the wider tires-
235/40-17 or 245/40-17 fit and will clear the suspension. More negative front and rear camber will help to tilt the tire inward so it doesn't look too wide,
see
https://www.northamericanmotoring.co...5-40-17-a.html
Here the R53 Cooper S owner used 17x8 et45. The fronts fit OK with 235/40-17 (slight rub) but the rears rubbed due to the dropped suspension using lowering springs.
File Type: jpg
Old Jul 10, 2014 | 12:13 PM
Lil Munchkin
see
Okay wow!! Thanks. You explained so much and helped a lot. Thanks for taking the time and doing all that for me. And yes I do plan on lowering and 17x9 just sounds like so much work after all that you have explained. I don't want to run Into any problems or issues either so I think it might be best for me to stay away from that wide. I do want some poke and stretched tires as well it's just that I can't seem to find some wheels to my liking. I was loving the str 520 but don't want to deal with the 17x9 issues. They have smaller wheels but I don't want anything under 17 inch. Thanks for all the help.
Old Jul 10, 2014 | 12:16 PM
Lil Munchkin
I did actually plastidip my wheels white and I'm loving the look so I'm going to be sticking with those for a while. Looking Into dropping her though, any suggestions? I have 16in rims right now and lots of ugly wheel gap lol. I'll try to post a pic later today.
Piolk
Feb 13, 2016 11:47 AM
dubfelgenwerks
Apr 24, 2014 08:43 AM
ESMWheels
Tires, Wheels & Brakes
54
Sep 30, 2013 08:52 AM
Boosted_Mini
Tires, Wheels, & Brakes
Jun 27, 2011 03:50 PM
JPMM
48
Feb 18, 2011 04:39 PM
