Official F56 Wheel Fitment Thread
Old Jun 23, 2015 | 06:02 PM
  #276
KazO's Avatar
KazO
These are 17x7 ET43 with factory-size 205/45/17s
Attached Thumbnails Official F56 Wheel Fitment Thread-dsc02465.jpg   Official F56 Wheel Fitment Thread-dsc02467.jpg   Official F56 Wheel Fitment Thread-dsc02464.jpg
Old Jun 23, 2015 | 06:19 PM
  #277
gbuff1's Avatar
gbuff1
Thanks--looking for lightweight 15" track wheels.
Old Jun 23, 2015 | 06:58 PM
  #278
randomquickness's Avatar
randomquickness
I know of a cool 16" that would work with a stud conversion but sadly the smaller diameter wheel options are quite limited.
Old Jun 24, 2015 | 07:36 AM
  #279
VicSkimmr's Avatar
VicSkimmr
Originally Posted by knecht
Thanks for the great ideas. The spacer and Speedlines are great options. I reached out to the person I've been working with NM and he agreed spacers may work. It appears they haven't given up as they are getting a JCW brake so they have something to work from. I'll keep you posted.
Sweet
Old Jun 25, 2015 | 05:48 PM
  #280
J_L's Avatar
J_L
Cool- are those the VW Heritage wheels? Did they fit without any modifications? I'd love to see them in black... and lowered... =)
Jeff
Old Jun 25, 2015 | 06:25 PM
  #281
KazO's Avatar
KazO
Jeff
There are ways to get away without modifications to get around the small centerbore and different lug seats, but I was changing from black to white so I had all the proper machine work done.
Old Jun 28, 2015 | 06:12 PM
  #282
ludrof11's Avatar
ludrof11
Has anyone tried fitting 9's yet? Looking at getting 18x9 et22. I know they'll poke about 1.5in but can pull them back in with a little bit of camber
Old Jun 28, 2015 | 06:27 PM
  #283
randomquickness
I'm pretty sure you will need to stretch tires a bit or do a fair amount of trimming to the plastic fenders
Old Jun 29, 2015 | 04:28 AM
  #284
jamesdean's Avatar
jamesdean
Yeah you will have lots of clearance issues especially if you go low. Wheel wells are not forgiving in the F56. I have only 75" wide but my tires are 8.5" wide et 45. I clear the rear fender by 3-4mm and the front struts by 3mm. Front camber is .8 rear 1.7.
Front wheel
Old Jun 29, 2015 | 06:40 AM
  #285
VicSkimmr's Avatar
VicSkimmr
9's will not fit without widened arches or a modified rear trailing arm or extreme camber/tire stretch.
Old Jun 29, 2015 | 08:20 AM
  #286
ludrof11's Avatar
ludrof11
Plan on doing this. Thinking of trying to rig a way to make the mk5 flares work on our cars
Old Jun 29, 2015 | 09:28 AM
  #287
VicSkimmr's Avatar
VicSkimmr
Please make sure you post updates
Old Jun 29, 2015 | 09:47 AM
  #288
ludrof11's Avatar
ludrof11
Will do! Hopefully will be taking off one of my fenders this week and seeing if the curvature is the same as the mk5's. Would be awesome if they are close enough to make it work!
Old Jul 11, 2015 | 09:42 AM
  #289
honderpilot's Avatar
honderpilot
I'm looking at 17x8 et 35 on stock suspension... thoughts? rubbing? The only issue I foresee is poking out... a lot....
Old Jul 11, 2015 | 10:59 AM
  #290
randomquickness
^search my build thread and there are a few photos of this
Old Jul 11, 2015 | 01:07 PM
  #291
honderpilot
I will check it out. Thank you!
Old Jul 12, 2015 | 11:41 AM
  #292
VicSkimmr's Avatar
VicSkimmr
Depends on how low you plan on going with it.
Old Jul 14, 2015 | 10:26 AM
  #293
honderpilot
Originally Posted by Inlinejohn
Complete 😊 "for now" Maybe black Viper stripes next
Rse12 18 x 7.5 ET45
Michelin Pilot Sport AS3 P205/40R18
H&R Sport Springs
18% Tint
John, do you have any clearance issues? Rubbing or anything?
Old Jul 14, 2015 | 12:23 PM
  #294
slumpey's Avatar
slumpey
Hmm...Is that an Acura NSX i see in the garage?
Old Jul 15, 2015 | 01:25 AM
  #295
jamesdean's Avatar
jamesdean
He is running a stock size tires which is narrower and less diameter than mine plus the H n R springs have less drop and same offset so he will S not rubbing.
Old Jul 15, 2015 | 05:47 AM
  #296
honderpilot
Ok sweet! Thanks James.
Old Jul 15, 2015 | 12:10 PM
  #297
SCoopa's Avatar
SCoopa
Wheel fitment has always baffled me. So here's what I am up against. I have a 2016 JCW coming. I am looking at dropping it on either BC or KW V1s (not sure on which one of these either). I am trying to figure out if I can get a 18 x 8.5 (either et 35 or45) to fit. Any ideas or thoughts?
Old Jul 15, 2015 | 12:20 PM
  #298
honderpilot
I was seriously considering those exact wheels about a week ago. Frankly I didn't like the look of them on the f56 but they should fit but they will poke out big time. Idk how low you'll be able to go with coils without rubbing
Old Jul 15, 2015 | 01:09 PM
  #299
VicSkimmr's Avatar
VicSkimmr
Yeah, an 8.5 won't fit in the front without some poke. IMHO, R99's setup of 18x8 et 45 in the front is the best fitment I've seen. You could probably fit an 18x8.5 in the rear.
Old Jul 15, 2015 | 01:52 PM
  #300
SCoopa's Avatar
SCoopa
Yeah, that's what I thought. I may follow in R99s footsteps ..
