Wheel Opinions - Pic Added!
Great looking wheels! Luv the IB!
Both Ken and I lowered our cars without rubbing issue. Depending on the off set of the wheels and tire size and lowering springs, you may or may not have rubbing issue.
_________________
_________________
Kypt, those wheels look good on your ride. I waas looking in to the gunmetal version last year and was even thinking about them again before I finally decided on the JCWs.
I do not know what itre brand and size you went with but because of the 40mm ofset they will most likely rub if you have someonbe in the back seat. My Antera 309s had a 40 offset and thats what they did with they stock suspension.
With that 40mm offset, I would definately keep a nice coat of wax and polish on the doors. I hated the way the tires kicked up junk and sand on the car.
Later
Later
I actually kept the stock run-flats for now (not sure the size off the top of my head). When those are no longer useful, I'm going to switch to regular 'get-a-flat-and-you're-screwed' tires.
>>Aren't the JCWs 18s? Are there issues with lowering springs for those?
The JCW wheels are 18" and the recommended tires are 105/40/18, which I'm using in my car. With Alta springs, the car has no rubbing. :smile:
little blingy for my tastes....
but your stance is hottt!
personally i prefer the color matched polished gunmetal.
_________________
LeftSideProductions.rave-links.net
2004 04 MCS DS/DS
This is THE stance
_________________
LeftSideProductions.rave-links.net2004 04 MCS DS/DS
This is THE stance
DrDrumanbass, what size and kind of tires/wheels? What type of lowering springs
His, Chile RED over, Madness intake, Magnaflow exhaust, Helix 15% Pulley & RDR Swaybar
Hers, Electric Blue / Union Jack on top and BONE Stock
ltjpunk7
Sep 6, 2015 07:32 AM
