Wheel weight guide
The most complete list i've seen yet. One on here yet? Well here ya go. Sticky this!!
http://tmitbyh.napalm.net/wheel-weight-alpha.pdf |
Here are a couple more good sites:
http://www.clubcivic.com/board/sitem...p/t-85783.html http://www.measurespeed.com/index.php |
Any info on the R112 and R113?
Originally Posted by zmsamson
(Post 3673892)
Fits R50,R52, R53, R55, R56, and R57 R113 Cross Spoke 18x7" et52 23.1 lbs. (10.5kg), Bright turned or Gloss Black Fits R50,R52, R53, R55, R56, and R57 |
Minihune,
Do you know any details on the Rib Spoke 115 wheels? Thanks! |
Originally Posted by papatom360
(Post 3845190)
Minihune,
Do you know any details on the Rib Spoke 115 wheels? Thanks! see http://minicooper.wikia.com/wiki/OEM_Wheels_and_Tires I would expect the weight to be about 19 lbs. |
thanks for the site tips.
Here's another (not as informative) guide if the other links won't work for some reason:
http://libraryofmotoring.info/facts/wheels/ |
Originally Posted by minihune
(Post 3845172)
R112 Challenge-spoke 17x7" et48 23.1lb (10.5kg), Silver and Gloss Black
Fits R50,R52, R53, R55, R56, and R57 R113 Cross Spoke 18x7" et52 23.1 lbs. (10.5kg), Bright turned or Gloss Black Fits R50,R52, R53, R55, R56, and R57 I have the R112 wheels and without tires, wheel weights or center caps with my digital fish scales they weigh 20lbs 10oz, not 23.1lbs! |
Wheel Spacer help please / 2012 JCW / R 105
I find great info here. I learned before trying that I need wheel spacers to fit my R 105s with the JCW brakes. Stock sport suspension now, KWs maybe later.
I would like to balance between a flush look & great handling. Do I need a spacer greater than 5mm for future coil overs? What spacer thickness is best? For looks, flatter is better. For tracking direction & handling - spaced out more is not always good. Please help - buying spacers ASAP ! Thx |
