offset37mm with 215-45-17??
Old Sep 11, 2011 | 09:22 PM
junhyuk8901's Avatar
junhyuk8901
I have 17x7 Sparco Assetto Gara offset 37mm with 205-45-17 tires.
And, i am planning to upgrade my tires to 215-45-17. But, i am little worry about if it is going to rubbing or not.
Is anyone has this same set and have or had any problems with it?
I talked to the Alex(Tire Rack), and he said that it might slightly rub.
But, I just want to hear opinions from people who had this same set before i make decision.
By the way, my car is not lowered and no spacers.
Thanks.
Old Sep 12, 2011 | 04:11 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
I went up a size like you are considering with my 18's. They called my cell # just to make sure before processing. I asked that they process the order just the same and the set up was perfect. But I appreciated their concerns.
As far as Tire Diameter size, use this site Tire size/diamter It will give your a good idea visually with dimentions. Diamter wise the difference is marginal.
You can use this as a guide for offset: off set calc If you are running stock wheels with a 48et. Going to 37 et is like adding a 10 mm spacer.
As far as offset goes. I ran 38et in my 1st Gen and had no issues. If you have 2nd Gen I would think you would actually have more clearance than I had.
Miata13
Tires, Wheels, & Brakes
Sep 12, 2015 04:18 AM
Mini Poopa
Feb 13, 2014 12:28 PM
k_h_d
Feb 12, 2013 12:07 PM
junhyuk8901
Sep 6, 2011 11:53 AM
wonderland130
Oct 22, 2007 10:21 AM
