winter tire use on stock wheels
Old Jun 30, 2011 | 10:47 AM
madmaxxed's Avatar
madmaxxed
good afternoon. after purchasing a set of new wheels and summer tires for my 2010 MCS I've been in the market for some winter tires for my stock wheels. I removed the TPMS units from the stock set up for the new set up. I found a good deal on a set of 215/55 R17 winter tires and i figured before it's too late i should snag them while i can. anyways, i don't plan on picking up another set of the TPMS units where i'll only be using these a few months out of the year. i was informed that's not an issue other then having the low tire pressure light on the guage appear at all times. my only concern is will i be able to run just a stand valve stem on the stock wheels or are they designed to run only TPMS valves?
Thanks in advance.
Old Jun 30, 2011 | 03:09 PM
oldtruckpainter's Avatar
oldtruckpainter
Thanks in advance.
A normal valve stem will work.
Old Jun 30, 2011 | 04:45 PM
MINI33342's Avatar
MINI33342
yep........only problem is the always on light.
Old Jul 1, 2011 | 09:12 AM
NH_MCS's Avatar
NH_MCS
You may run into tire fitment issues with the 215/55/17 size. That tire is going to be 2" larger in diameter than the 205/45/17 that came from the factory. The tires may end up rubbing on the inner fenders when turning and your speedometer will be way out of whack. Stick with a stock size or 215/40, or 215/45 tires.
Old Jul 1, 2011 | 09:31 AM
Blackbomber's Avatar
Blackbomber
I'd stay with a 205 section for winter use.
Old Jul 3, 2011 | 05:10 PM
madmaxxed's Avatar
madmaxxed
I am running a set of 15mm wheel spacers as well. I wasn't sure if I was going to keep them on during winter months but if I chose to that would probably help out with any rubbing issues right? I see a lot of people running several size tires not far off from what i'm thinking for a winter set up. I've even seen some with lowered suspensions. I would like to stick to the the OEM size but for the money the seller is willing to accept and the condition of the tires, i'd hate to miss out. I can deal with my speedo being off a bit.
Old Jul 4, 2011 | 08:07 AM
NH_MCS's Avatar
NH_MCS
Usually most people run a tire that's < .5" difference in overall diameter vs. stock. I just think the 2" difference you're going to have is way too extreme. That's an extra inch of tire sticking out all the way around. My 215/45's a slightly larger than stock, and I wouldn't want to go any bigger. How much money are we talking for a set of tires?
Old Jul 4, 2011 | 08:44 AM
madmaxxed's Avatar
madmaxxed
$200 for a complete set of winters. used only one season.
FLYM1N1
Oct 13, 2015 04:33 PM
ltjpunk7
Sep 6, 2015 07:32 AM
Dashdog
Aug 10, 2015 06:17 AM
jcb-memphis
Aug 8, 2015 11:09 AM
