17x7.5 et38 all around?
Old Mar 17, 2011 | 07:22 AM
jump'n'jive's Avatar
jump'n'jive
will these fit the r53 or will i run into fitment issues? also what is the minis center bore?
Old Mar 18, 2011 | 06:06 AM
Alex@tirerack's Avatar
Alex@tirerack
With 205/45 no issues, Possible slight rub on rear bumper brackets with 215/45. The centerbore is 56mm.
Alex
Old Mar 18, 2011 | 06:18 AM
jump'n'jive
would you go with the 205/45/17 or the 215/40/17? i'm having to make that decision right now
Old Mar 18, 2011 | 01:53 PM
MiniKar's Avatar
MiniKar
I would stay with the 205's
Old Mar 18, 2011 | 03:28 PM
iwashmycar's Avatar
iwashmycar
same spec wheels with a stock 205.45.17
more slammed
you can see they fit just fine. I like the narrower tire for more clearance, but a 215 could be fine.
since your in a 53 id say use a 205
Old Mar 18, 2011 | 03:33 PM
iwashmycar's Avatar
iwashmycar
these are also the same specs on a 53. these are 205/45s
Old Mar 19, 2011 | 03:29 AM
howsoonisnow1985's Avatar
howsoonisnow1985
205/45-17 is stock size.
Shorter Overall Diameter of a 40 series compared to a 45 series tall tire will somewhat compensate for tire weight and will yield better gearing with smaller overall diameter. While, 215 width will yield better grip. Bi-Winning!
Chibi2
May 19, 2016 03:46 PM
DrFraserCrane
Aug 30, 2015 01:11 PM
sjmcs
Aug 3, 2006 08:31 AM
Alex@tirerack
Tires, Wheels, & Brakes
Oct 4, 2002 03:00 PM
