Big problem going from runflats to non-runflats
Old Jul 10, 2010 | 06:32 PM
R56 Wi MINI's Avatar
R56 Wi MINI
The problem actually has nothing to do with the tires, ditching the stupid run flats is something I should have done right away. The problem is that the person that drove my car while at the tire shop must not have known how to use the disc style key and completely screwed up the disc ignition system. The disc no longer just slides in prior to startup and slides back out upon shut off. I have to struggle to get it in and out. Sometimes I have to pull so hard on it to get it out that I feel like I am going to pull the dash off. I phoned the tire shop right away when I got home and discovered this problem and I will be talking to the manager on Monday demanding the he pay for the part to be fixed.
Has anyone had any issues like this and how did you fix it if you were able to? Thanks.
Old Jul 10, 2010 | 06:58 PM
strobeyprobey's Avatar
strobeyprobey
If you are struggling with it you can use the emergency backup system!
Stick the FOB in the slot (but don't need to click it in).
Press and hold the start button for something like 30 seconds. The car will start for you!
I just would hate to have the fob stuck in the dash.
Old Jul 11, 2010 | 06:21 AM
sequence's Avatar
sequence
wow, yet another reason to say: "Thanks, but please allow me to drive the car in and out of your service bay."
Old Jul 11, 2010 | 06:41 AM
ronnie948's Avatar
ronnie948
I stood and Watched.
I not only asked if he was famialier with the Mini Fob but I was with him and watched very closely as he started my Mini and drove it into the shop. He said they do a lot of Mini Coopers there so he was famialure with them even to resetting the TPMS.
I also watched to make certain that he did not yank my drivers door glass or slam my door. He was very careful with my car and treated it fine.
Old Jul 11, 2010 | 02:05 PM
Capt_bj's Avatar
Capt_bj
there are shops and there are shops
A good shop doesn't mind if you watch . . . a really good shop allows you in the garage. But this shop is probably a small independent. Chains will throw the "insurance reasons" flag on you. I try to avoid them.
Some chains have a simple row of bays and they can't stop you from standing right outside .... and yelling STOP!!!!!
Kimolaoha
Dec 5, 2020 09:32 PM
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
Colt45Magnus
Sep 7, 2015 10:47 PM
ASRman
Aug 13, 2015 09:33 AM
oldsbear
Eastern Iowa MINIs
Aug 9, 2015 04:02 PM
