rub?
Old Jan 27, 2010 | 04:10 PM
herbie hind's Avatar
herbie hind
rub?
will 20 mm offset rub? 16x7
Old Jan 27, 2010 | 04:15 PM
cmt52663's Avatar
cmt52663
even if it doesn't, it is going to raise hell with the front end geometry...
it's probably a good idea to keep the center of the contact patch somewhat aligned with the centerline of the front wheel bearings.
side effects will include accelerated FW bearing wear, and hyper-sensitivity to road camber
the stock wheels are +48 mm
I'm running 15x7 +38 and that car is darty, to put it mildly...
try this for a visualization of what I'm on about
http://www.wheelsmaster.com/rt_specs.jsp
cheers,
charlie
Old Jan 27, 2010 | 05:24 PM
glnr13's Avatar
glnr13
if you're even a hint lowered that offset will without a doubt rub. not only will it rub but you're poking out past the oem arch by about 1/2"
Old Jan 27, 2010 | 07:27 PM
herbie hind
the pokin out is good . i like !!!! the wheel bearings i could give a ***** about . i'm just wondering if it'll rub lol
i thought oem was 42mm?
Old Jan 27, 2010 | 07:29 PM
herbie hind
Old Jan 27, 2010 | 07:46 PM
glnr13's Avatar
glnr13
hehehe well then these will poke for sure. you're gonna be popping off arches on bumps but a little double stick tape and/or some dremelling will help keep them on.
most of the oem 7" wide wheels are et48.
http://www.mini2.com/forum/faq.php?f...q_faq_bolt_etc
Old Jan 27, 2010 | 07:54 PM
herbie hind
it aint lowered but if it'd be that bad i'll do some 38's . just doin cheaps cause the roads in ma. suck .
Doc Pain
Mar 10, 2021 04:50 AM
freeman727
Dec 10, 2017 04:00 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
Amberleigh MacIntyre
R55 :: Clubman Talk (2008+)
Nov 11, 2015 11:59 AM
Carwash
Sep 15, 2015 02:02 AM
