North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   Tires, Wheels, & Brakes (https://www.northamericanmotoring.com/forums/tires-wheels-and-brakes-36/)
-   -   Do these 18's fit on a 2009 clubman s? (https://www.northamericanmotoring.com/forums/tires-wheels-and-brakes/179426-do-these-18s-fit-on-a-2009-clubman-s.html)
isthar Dec 6, 2009 11:24 AM
Just out of curiosity...
Front Wheel Width: 8 inches
Rear Wheel Width: 8 inches
Wheel Finish: Polished
Wheel Condition: Brand New
Bolt pattern: 5 X 114.3 / 5 X 4.50
Dual Drill Bolt pattern: N / A
Front Wheel Offset: +45
Rear Wheel Offset: +45
Can those fit?
And... if those wheels are not TPMS, is there:
a) a retrofit
b) a way to just ignore TPMS?
this is /just/ in case I get to reuse some wheels I have for summer.
isthar Dec 6, 2009 11:44 AM
Ah, nevermind.. the obvious! 4 bolts, not 5...
iwashmycar Dec 6, 2009 05:17 PM
If you reeeeaaallly like them:
there are adaptors out there.... seeing they have a rather high offset you could sandwich in an adaptor and maybe be ok... granted thats going to cost more bucks.
as for TPMS... you can use your stock sensors, buy new ones (150-200 bucks), or have the idiot light on at all times w/o them..
Alpha Motoring Dec 6, 2009 05:40 PM
Sounds like a Nissan SE-R fitment
VicSkimmr Dec 7, 2009 08:04 AM
Other than the adapter requirements, 18x8 et 45 is a pretty common fitment. You could use an adapter that was up to 15mm wide without much rubbing (assuming the car is lowered), but I wouldn't use anything much wider than that. I guess you could always adjust camber if the adapter needs to be wider than 15mm, or just run some poke.
isthar Dec 7, 2009 02:45 PM
you guessed it ;-) That was my trade-in for the mini... I'm either selling the rims, or using them.
iwashmycar Dec 8, 2009 05:34 AM
well if your not already buying them... maybe research the sdaptors... probably about $200(?) for good ones
edit: cant really find them... nobody wants to really go from 4 to 5 or anything to anything for that matter
