North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   Tires, Wheels, & Brakes (https://www.northamericanmotoring.com/forums/tires-wheels-and-brakes-36/)
-   -   Guess I'm going back to 17's.... (https://www.northamericanmotoring.com/forums/tires-wheels-and-brakes/175812-guess-im-going-back-to-17s.html)
orangecrush Sep 19, 2009 07:11 PM
I think this is my final decision.... I guess. :roll:
I bought a set of 17" OZ Ultraleggeras and an identical set except in 18's. After much thought, I decided to use the 18's on the street. (they have Yokohoma S drives on them) and keep the 17's for the track with a set of high performance street tires.
I didn't want to do the R compound track tires only because I don't feel I have enough experience on the track and feel that track tires will allow me to overdrive my abilities.
So my dilemma is I drive to FL from NC to see my mother at least once a month. (before my father passed away in Dec., I was driving there every two weeks) Point is, I felt comfortable with the runflats.
Now that I'm running the Yoko S drives, I'm leary about driving 7-8 hours worth of driving one way without a spare or runflats.
Soooooo, I've decided to put the runflats back on the 17's and drive them. I figure when they wear out, I can buy next to new ones pretty cheap (With roughly 3000 miles on my Dunlop runflats, I couldn't even sell them for 300 bucks. I see them all the time pretty damn cheap on the forum)
I'll run the S drives at the track until they're gone and depending on how long that is, I found a set of Hankook RS2's that have been discontinued at Tire rack for about 80 each. After reading the reviews, it seems that they are a great tire for the money for the track.
By then, my skill should increase enough that I can use R compound tires. I did note that the difference between 17's and 18's for a decent tire is about 70-80 bucks per tire. Even if it costs me an add'l 300'ish for a set of track tires, for the amount I'll use them (6-7 track events per year) I'll get a year out of them.
Doesn't this sound logical?
Thanks,
Mark
minihune Sep 20, 2009 11:19 AM
Sounds ok but the runflats are not going to help that much if you have a really long drive. Just enough to get to a safe point and fix the flat.
Another option is to find a spare wheel and tire even 15 or 16" to take along with you in the boot covered by bag to keep clean and use it if you get a flat to get to a safe area but you'd still have to do a tire change in the dark or on the side of the road. If you have larger brake calipers then you'd have to make sure the spare wheel will fit.
ron-s mini Sep 20, 2009 12:40 PM
You could also get even smaller miniature doughnut spare to use when traveling.
orangecrush Sep 20, 2009 01:17 PM
I agree but better to be able to drive a bit to somewhere I can buy a tire than be left sitting on the side of the road.
Two issues... with the JCW, brakes are definitely bigger but more importantly, not only will I have to carry a tire now but a floorjack, tire wrench, etc, etc....
Think I'll stick with the runflats.
Mark
