Re-Balancing Wheels ???
Old Jun 18, 2009 | 06:22 AM
darkknight-nyc's Avatar
darkknight-nyc
Just bought '04 Mini w/ 16" OEM rims. The tires have about 20% tread left.
I bought another set of 16" OEM rims (different style) from a neighbor who upgraded to chromes after purchasing. The tires have 95% tread left and are from a '05 Mini.
Do I need to re-balance the tires that I got from the '05 Mini?
Old Jun 18, 2009 | 06:45 AM
gnatster's Avatar
gnatster
Unless the tires have been removed from the wheels there is probably no reason to re-balance. You should be able to bolt the new, to you, wheel/tire packages and motor away. If there is a vibration then you'll want to look into having them balanced.
Old Dec 9, 2009 | 08:21 AM
wloprete's Avatar
wloprete
Dealer cost head's up
I recently purchased a set of barely used Conti all-season tires mounted on Bridgespokes from an NAM member. Living in the Northeast, I intend to use these in the winter months on my '08 MCS, saving my Webspokes w/ Dunlop Sports for the Spring and Summer.
I took them to my dealer to be balanced and swapped. When I arrived for the scheduled appointment, I was told that the 'book cost' for balancing is .3 hours per wheel! If the shop rate is $130/hour, do the math!
Bottom line, this job at the dealer cost me over $160. When I questioned this, the response was that they have trained technicians using the most advanced balancing equipment, as opposed to the chain tire businesses who charge $30 to balance all 4 wheels.
I would love to hear comments from other members on what I am thinking is a dealer rip off.
Old Dec 9, 2009 | 11:43 AM
tgs91
I had mine balanced after a suspension mod by a credible local tire shop I trust-think it was $70-$75
Old Dec 9, 2009 | 12:14 PM
chubbycheddar's Avatar
chubbycheddar
I got mine mounted and balanced for 70 bucks. I don't think anybody does it for 30 but 160 is high, but not surprising since you took it to the dealer to have it done. i think anything that the dealer does is a rip off but everyone knows that right? although sometimes you have/should
Old Dec 9, 2009 | 12:27 PM
MNCRYSS's Avatar
MNCRYSS
Most larger tire service companies have the same modern equipment the dealers have and the same amount of knowledge regarding balancing. The only time to rely on a dealer is to troubleshoot something particular to that brand. Most other services are identical to everyone else in the industry.
Old Dec 9, 2009 | 12:47 PM
veggivet's Avatar
veggivet
There's a reason they call them 'stealerships'.
Old Dec 10, 2009 | 07:37 AM
slinger688's Avatar
slinger688
There are two main types of wheel balancing, which one is better, I have gotten some conflicting info about which one is "better".
Regular Balancing
Road Force Balancing
I tend to favor road force as it actually rotates the wheel and the tire and divides the wheel into segments. It then recommends a balance (weight) for each segment.
Like VV said, I would not go to the dealer for this.
barnoun
Sep 17, 2018 05:04 PM
khumpert
Nov 30, 2015 11:48 AM
SosoMINI
Nov 22, 2015 03:17 PM
Tires, Wheels & Brakes
Aug 26, 2015 11:02 AM
BowserKart
Tires, Wheels, & Brakes
Aug 20, 2015 01:24 PM
