Factory wheels painted or powder coated?
My car came with gray wheels and I ordered white ones. The dealer said they would paint the gray ones white free of charge. Are the factory wheels painted or powder coated? Is there anything wrong with them painting them? I assume the factory finish would be better but is this common?
Thanks.
Thanks.
That is great they are willing to paint them for you. But even if they can match the factory finish and even if they powder coat it, they are not what you ordered, and you will have two coats. This second coat will add an un-noticeable amount of weight, but if you have documents saying you ordered white wheels they should replace what you have with what you ordered.
OEM Wheels are painted from the factory. As long as it's a reputable shop, they should be able to match the factory finish. It's up to you whether you go that route or request replacements. It would not be that hard for your dealer to source you new factory white wheels, so it wouldn't be out of line to request them to just order you some new white wheels.
Ya after thinking about it you are right, but like you and I said. The OP ordered white wheels, they should fix the problem by ordering what you are supposed to have. They can paint or not paint the wheels that came with yours and sell them themselves.
Unless there is some kind of warranty on the paint have them deliver the car with the gray ones then order you real white ones from the factory. Our car had a big scratch in one of the wheels at delevery. The dealer offered to fix(paint) or order a new one for the factory. As they say "aint nothing like the real thing."
I really liked these :
http://cgi.ebay.com/ebaymotors/Mini-...82171694593263
Slick way they painted the spokes and left the outer rims silver
Does this make financial sense to anyone?
Receive car
Dismount wheels
Dismount tires
Strip wheels
Paint wheels
Remount & balance tires
OR
Order correct wheels on next car, swap when received
Seems like the latter would make more sense both financially and effort wise. Why strip/paint perfectly good wheels when the correct part can come over on the next boat?
Receive car
Dismount wheels
Dismount tires
Strip wheels
Paint wheels
OR
I didn't like the other work but liked the way the wheels were painted...
You must remember too , that his wheels are USED (he's saying brakes need replaced)how would you feel to buy a new car and get old scratched up wheels on it ... The painting solution is about the only way to remedy the situation
It's most likely much cheaper and easier to paint wheels than order a whole new set as well as paying shipping. Otherwise the dealer is stuck ordering a whole new set of wheels and paying to ship them in rather than just shelling out $200 to have them re-painted.
Yah, I'm not a fan. They detract from the mismatched sideskirts too much
you don't like the stickers to make the fenders look vented? I haven't seen work like that since it was done on a Monte Carlo
Drew: Bear in mind that the factory wheels come with a clear coat. Found this out when I had my R98's(pretty sure they're the same for all wheel models) sandblasted to be powdercoated. So definitely make sure that the painting done by the dealer has a clear coat on it. And unless I'm doing a difficult custom color, I would go for powdercoat over paint.
No, the car is BRAND NEW. I want to put new low dusting brake pads on it right away so I can keep my pretty white rims just that, white.
You may want to check with an independent painter and see how long they would wait on the paint before using.
Don't know if you have this issue fixed yet, but the same thing happened with me, with the order at least.
I ordered my car with white wheels, it came in with gray. I told my SA that I had ordered the white wheels and he apologized and put out an order for OEM white wheels. Basically, he ordered a car from the MINI plant with white rims. I had to wait a few months for that car to come in so he could switch them off. It was a little bit of a pain but it was all free of charge.
07-16-2020 12:54 PM
12-23-2015 10:36 AM
The_Kid
08-18-2015 03:12 PM
