New OZ Racing Alleggerita HLT
Old Oct 11, 2008 | 03:38 AM
  #51
Damo's Avatar
Damo
Anyone fitted these yet, and any info on an 18" version?
Old Oct 11, 2008 | 01:10 PM
  #52
tazio's Avatar
tazio
Alex!?
Old Oct 23, 2008 | 01:33 PM
  #53
Duffer's Avatar
Duffer
When is this going to be available?
Old Oct 23, 2008 | 07:46 PM
  #54
tazio's Avatar
tazio
Alexander!
Old Oct 24, 2008 | 04:39 AM
  #55
oxtox's Avatar
oxtox
their site says available 12/22/08
i guess i know what santa's bringing me.....i get lighter, look better, and can ditch the spacers i needed after my coilover install
Old Oct 24, 2008 | 09:15 AM
  #56
Alex@tirerack's Avatar
Alex@tirerack
Alex, do we have an official offset spec on these?
We will have weight data once we recieve them. 17x7et 37
Also, is it really the case that you will not have any in stock until December?
Were expecting 12/22 -based on a container departing Italy in end of November.
Can you give a sense of how well the "Titanium" finish matches Mini Dark Silver?
Check out these actual photos
PS - if you need a faster anwser - email me - if you can't wait - call me
Alex
Old Oct 24, 2008 | 12:22 PM
  #57
Duffer's Avatar
Duffer
Will these ever be available in 16"?
Old Oct 24, 2008 | 12:46 PM
  #58
Works's Avatar
Works
In the Ultraleggeramodel, the HLT process is used only in bigger sizes (>= 19"). I love to see it in smaller sizes too.
Old Oct 25, 2008 | 07:26 AM
  #59
Alex@tirerack
17 and 18's are all that are currently offered across this model, regardless of appication.
Alex
Old Nov 9, 2008 | 11:03 AM
  #60
swgn's Avatar
swgn
The international OZ Racing website has a bunch of new information about these rims, including weights, plus some photos of them fitted to an R56!
http://www.ozracing.com/at-team/whee...ggerita-hlt/en
Old Apr 13, 2009 | 09:52 AM
  #61
scottab36's Avatar
scottab36
Will these fit over the JCW Sport Brake Kit? Is this available in the 17/7 ET44?
Old Apr 13, 2009 | 10:13 AM
  #62
newbs49's Avatar
newbs49
Now we need Tire Rack to get the 17 x 8 .
Old Apr 15, 2009 | 07:09 AM
  #63
Alex@tirerack
Yes they will
17x7 et37 would be the only 4-100 we have.
Alex
Old Apr 15, 2009 | 08:25 AM
  #64
newbs49's Avatar
newbs49
Can the 17 x 8 be ordered?
Old Apr 15, 2009 | 06:08 PM
  #65
scottab36's Avatar
scottab36
Originally Posted by Alex@tirerack
Yes they will
Alex
Your Right Alex!! Here they are...
My work is almost done!!!
Old Apr 18, 2009 | 02:17 PM
  #66
RaceTripper's Avatar
RaceTripper
I'm looking at getting these in white within the next month or so. Will they work OK with a 215/45/17 tire (like the Bridgestone RE-11) on a JCW. Is it possible to go even wider, to a 225/40/17?
Old Apr 18, 2009 | 02:38 PM
  #67
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
OK with 215/45-17 and stock suspension. If you are lowered then you may have a little less clearance and risk of some rubbing in the rear due to +37 offset which makes the rim and tire stick out a little more.
225/40-17 technically can fit but tire selection is very limited for street tires-
tirerack only shows race Hoosier A6 and R6 tires not for street use.
Nitto has the NT-555 in that size for about $160 each 300 treadwear.
Old Apr 18, 2009 | 02:49 PM
  #68
RaceTripper
I may end up getting the JCW suspension kit (I'm modding in order: wheels/tires, suspension, power). IIRC, that lowers it by about 1/2" Is that enough to worry about, or should I stay size stock with 205/45 tires?
Old Apr 18, 2009 | 03:02 PM
  #69
minihune's Avatar
minihune
If you are lowering you will have more clearance if you are using tires that are stock sized and not much larger.
RE-11 comes in 205/45-17 and will fit the 17x7 rim better and is lighter in weight and costs $9 less. It has a lower sidewall vs the 215/45-17 so it will handle a little better in corners.
The reason to have clearance is if you drive over uneven surfaces or carry back seat passengers you don't want to get rubbing as your drive along.
If you have very smooth and flat roads and you drive the speed limit only and carry only one person in the car then a wider and taller tire would work OK up to a point.
Old Apr 18, 2009 | 03:09 PM
  #70
RaceTripper
Thanks. Then I'll think about staying with the 205/45s. This car is going to do duty during the year as a daily driver, for 3-4 longer road trips, and for a couple DEs. I'm keeping my Challenge wheels with all-seasons for winter months (Nov-Feb).
Old Apr 19, 2009 | 04:51 AM
  #71
scottab36's Avatar
scottab36
The wheels pictured above your post are mounted with 215/45/17s.
Old Apr 19, 2009 | 07:52 AM
  #72
RaceTripper
Yes, but I may get the suspension kit at some point and am worried about rubbing. The 205/45 size sounds like a safer bet.
Old Apr 22, 2009 | 12:04 PM
  #73
masterd78's Avatar
masterd78
MANIAC
I can post pics later, but I got the whites with 205/45 RE-11's and they look to fit fine with my cross coilovers. I will check the outside edge later and make sure there is no flare rubbing. I will post pics when I get my car back!
Old Apr 22, 2009 | 12:08 PM
  #74
RaceTripper
Please do post. I'd love to see how the whites look in the wild.
Old Apr 22, 2009 | 09:50 PM
  #75
masterd78's Avatar
masterd78
MANIAC
Here are some pics! Front is going a bit lower tomorrow! They clear my cross coilovers without spacers, and the rears are about a 1/4" from the inner lip of the flare.
