17x7 ET38 with lowering springs on R56?
Old Feb 27, 2008 | 07:12 PM
MiniJayhawk's Avatar
MiniJayhawk
I like the thought of a wider stance with the 38 offset, but will I have a problem with 215/45/17 tires on a lowered R56 (springs)? Do I have to keep the offset in the low to mid 40's?
Old Feb 27, 2008 | 07:17 PM
PGT's Avatar
PGT
ET42 is best with 215/45 though worst case is a little dremel work
Old Feb 27, 2008 | 07:23 PM
MiniJayhawk
PGT, have you checked out the R56 to compare wheel well room vs your car? I hear there is more room, but in which directions? I have seen some pretty crazy setups to think that a 38 offset wouldn't work.
Old Feb 27, 2008 | 07:53 PM
PGT's Avatar
PGT
Mach V is running 235/40/17 on 7.5ET45 with no issues. I'd have to run the delta on the two apps to see, but I think there's more outboard than the R53.
Old Feb 27, 2008 | 08:06 PM
scott48's Avatar
scott48
I actually plan on running the exact same setup, so any info about any clearance issues would be great.
jeremy_reyes94
Sep 6, 2019 07:53 AM
melscoop
Mar 30, 2016 06:56 PM
G1HQ
Aug 28, 2015 01:41 PM
yukinoinu
15
Aug 24, 2015 09:20 AM
Emnotek
Aug 13, 2015 05:47 PM
