North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   Tires, Wheels, & Brakes (https://www.northamericanmotoring.com/forums/tires-wheels-and-brakes-36/)
-   -   Don't know enough... (https://www.northamericanmotoring.com/forums/tires-wheels-and-brakes/119527-dont-know-enough.html)
sterfsky Nov 9, 2007 08:37 PM
I have tried to search for what I am looking for, but I think I need some help...sorry in advance!
I have an 05 MCS that currently has 16" rims with all season runlflats on it. I live in Duluth and was going to get the Blizzaks and want to get new rims to mount the tires on and not have to take the run flats on and off with the season change. Would it be okay to run 15"? (since they do seem to run a bit cheaper) And where would be the best place to get the wheel and tire package? I have looked on tire rack and just not sure if I have the money (if I have to go the 16" route). When I talked to a guy at Firestone last, he told me his 15" Blizzaks were $84 a piece, which sounded pretty great to me. Just to find the rims I guess if you think that's a good price.....
Another random question....a friend I know has 14" rims with snow tires already mounted from a Honda with the 4x100 bolt pattern...would this clear the brakes?
Thanks in advance for the help :)
Eric_Rowland Nov 9, 2007 10:05 PM
To stay at the OEM diameter, you'd need a 175/65-15 (that's the stock size on the Cooper.)
You should be able to find a set of Cooper takeoffs if you want an OEM wheel. Try the marketplace. Here is a set of snow tires on rims.
I doubt the 14" would fit, but it's worth a try...
johned206 Nov 10, 2007 05:52 AM
The Tirerack deals aren't bad. Blizzaks mounted on the 15" steel wheels they have come in at $482 with the shipping included. Mounted, balanced, no fuss. Not a bad deal. Check out their packages with other snow tires and wheels and maybe you can come up with something that'll meet your needs and budget.
minihune Nov 10, 2007 09:30 AM
There are no 14" rims that fit the MINI that I know of. All are too small to fit over the brake calipers in front.
15" wheels and tires would be fine. Check tirerack first and plug in your MINI with the correct year and options and search for winter 15" packages.
Do you have stock suspension and stock front brakes? No JCW front brakes? For more information email or call Alex@tirerack.com
Tirerack winter 15" package search for 07 MCS shows-
For 195/60-15 (for studless Ice and snow tires), 185/65-15 is alternate size
Blizzak REVO-1 $58 each closeout
Blizzak WS-60 $78 each
For wheels
1 style of steel wheels at $38 each
or
45 alloy wheel styles from $81 each.
Choosing steel wheels and REVO tires x 4 gives $384 a set mounted and balanced plus shipping (wheel covers $27 a set)
or
with alloy wheels and REVO tires x 4 gives $556 a set plus shipping.
Some samples of alloy wheels
http://www.tirerack.com/images/wheel...e_f2_ci3_l.jpg
Sport Edition F2 Silver painted 15x6.5" +40 offset 17 lbs $81 each made in China
http://www.tirerack.com/images/wheel...cd_s_ci3_l.jpg
Sport Edition CD 15x6.5" Silver painted +40 offset $84 each 16.5 lbs made in China
http://www.tirerack.com/images/wheel...e_d4_ci3_l.jpg
Sport Edition D4 15x6" Silver painted +38 offset $84 each 15 lbs (closeout) made in China
http://www.tirerack.com/images/wheel...e_e3_ci3_l.jpg
Sport Edition E3 15x6 Bright Satin Silver Paint +45mm offset 15.6 lbs (made in Japan)
German made wheels from $89 each by Rial and Borbet (about 17 to 19 lbs each)
Crashton Nov 10, 2007 11:57 AM
I'm running 185/65/15 snows on my 06 MCS. I bought a set of used Holies off a Cooper. For tires I'm running Nokian Hakka 2's & have been very pleased with there snow performance.
