Roll call - 8"+ wide wheels
I thought it would be a good idea to make a thread for those of you who are running wheels with a width of 8 inches or more. Wide wheels isn't commonplace here on NAM and it can be challenging to find info if you're looking to go this route. I'm hoping we can create some sort of a database where one can find info on wide(r) wheel/tire setups.
So, if your running wide wheels, whether they are staggered or not, post all the specs and a pic of your ride.
For example:
Wheel/Model: BBS LM
Offset: 30
Wheel Size: 17x8, 17x9
Tire Size: 205/40/17, 215/40/17
Suspension: KW Coils dropped appx. 2"
Camber Settings: -1.5 F, -2.5 R
Rubbing: No
Pic: Insert Pic here
*NOTE* The above is purely made up for the sake of showing an example.
For example:
Wheel/Model: BBS LM
Offset: 30
Rubbing: No
I'll start us off... Hopefully Rally will keep us going
*NOTE* This is off memory, I'll look into it when I'm not here at the office.
Former member, D6-MCS.
Wheel/Model: Keskin KT4
Offset: ET35 F, ET25 R
Tire Size: 205/40/17, 215/40/17 (Bridgestone Potenza S-03)
Suspension: KW Coils dropped appx. 2.5"
Camber Settings: -? F, -? R
Rubbing: Cutting it close
Pic:
Pic:
Guess I'll post my pictures and stats yet again
Gonna probably be changing to new wheels next spring since these come off for winter soon.
Wheel/Model: BBS RM012 2-piece rims with custom Schmidt lips
Offset: ET13 F, ET8 R
Wheel Size: 15x8, 15x8.5
Tire Size: 205/50/15 on all four (Dunlop direzza)
Suspension: Megans drop=I dont know....a lot 2.5"+
Camber Settings: -2.5 F, probably -1.5 ? R
Rubbing: None up front...a little in the rear because i haven't set the camber to my specs yet. Arches were trimmed
Gonna probably be changing to new wheels next spring since these come off for winter soon.Wheel/Model: BBS RM012 2-piece rims with custom Schmidt lips
Thanks for the post Rally. So no one else out here is running wide wheels and a nice drop? Tire stretch or poke isn't a necessity to be part of this. Just a wide wheel in general...
Anyone?
Anyone?
Car has KW coilovers lowered about 1".
Now it's a perfect fit
Above setup re-formatted.
Wheel/Model: 949 Racing 6UL
Offset: 36
Wheel Size: 15x8
Tire Size: 225/50/15
Suspension: KW Coilovers - Lowered appx. 1"
Camber Settings: F - Stock, R - Minor negative camber
Rubbing: None
Ok now we are finally starting to get somewhere. I'm sure there are more of you running wheels wider than 7.5 inches. Please chime in else this thread is worthless...
Offset: 36
Wheel Size: 15x8
Rubbing: None
Offset: approx. +30mm (wheels are +36mm, with .25" spacer)
Wheel Size: 15x8
Tire Size: 225/45/15
Suspension: Stock Springs
Camber Settings: F: -2.25 deg, R: -1.25 deg
Rubbing: None (see above, stock springs
Wheel Size: 15x8
)Jason
Minihune posted them, an electric blue MCS right? Looks terrible IMO, does it actually help at the autox?
But yes, from what I hear the 275 Hoosiers produce some pretty amazing levels of grip!
Jason
IMO, there's no point in going fast if you look like **** (in a DD at least). Wide wheels are all about LOOKing good. If speed is your thing, go for it, with MCS I'm more interesting in looks right now...
If I wanted fast and a good handling car I would've gotten a beater CRX stripped it, done suspension mods, sohc with built internals and boosted running 11s all day long and destroying most of the cars at the local auto-x. All for less than I've spent in mods on my MCS. BUT, at the end of the day it's still an old pos crx...
Back to wide wheels and looking good.
If you think its ALL about the LOOKS your only half enjoying the MINI!
Oh believe me I'm enjoying my MINI to the fullest, there's more than a couple 350Z, G35, GTi, SRT4, WRX, etc. owners that can vouch for that
Go low or go home! Hahah
Ok you guys... let's get this thread back on track
Wheel/Model: Axis Decade
Offset: 40
Wheel Size: 18x8
Tire Size: 225/35/18
Suspension: H-Sport Springs & Koni Yellows - Lowered appx. 1"
Camber Settings: forgot the setting
Rubbing: none
And it's all thanks to WAKE|MCS
Offset: 40
Wheel Size: 18x8
Rubbing: none
Ca$per do you have any side shots available. (View down the side from front or rear.)
I am going to call on some 18x8 Giovanni rims that are missing the center caps tomorrow.
