Roll call - 8"+ wide wheels
Old Mar 26, 2017 | 07:37 AM
  #951
Bnourai's Avatar
Bnourai
Originally Posted by elijahallmond
im looking into buying some wheels very soon and i cant find anything about a 2002 base model mini cooper fitment. Im looking on putting 17x8.25 on all fours and idk if theyll rub or scrape. I do have a fender roller and i plan on putting a 1.25" drop on it as well. Any help?
I had a set of XXR 17x8.25 et22 on my 09 s you can see it on this page I also had eBach lowering springs on billstin b4 the wheels were right to the edge of arches the only time they ruled was when I hit a strong dip and it was to a minimum but I just went with 16x8 et33 and coilovers my car now is kinda slammed and still to the edge of my arch but the innermost.
I think after 4 sets of wheels in 4mo I found a right ET.
Ben
Old Apr 18, 2017 | 10:06 AM
  #952
elijahallmond's Avatar
elijahallmond
desperate
I need help. i need advice for fitmetn. i want 17" all around for a 2002 base model. I need offset and i do plan on rolling the fenders etc.
Old Apr 18, 2017 | 05:45 PM
  #953
mini coop's Avatar
mini coop
17 inch, 7 inches wide and 30 et will be flush with the fender flares. At stock height they will not rub the fenders.
Old Apr 18, 2017 | 05:49 PM
  #954
elijahallmond
but what if the wheels I'm looking at are 7.5 wide.
Old Apr 20, 2017 | 03:24 AM
  #955
mini coop's Avatar
mini coop
At stock oem height you should still be good. It's when you lower the car that a higher offset will be needed.
Old Apr 28, 2017 | 04:11 AM
  #956
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Ok guys, I want some assistance...
I would like to get new wheels for my 2012 R55 Clubman, and I'd like to go 17x8. I'm looking at the TR Motorsports C4 which comes in a 17x8 +45. I would initially mount my stock 205/45-17 tires on them, and I'm currently running stock suspension. In the future, I'd like to go up to a 215/45-17 tire and convert the car to coilovers for a lower ride.
Will I have any clearance issues or concerns with this configuration?
Old May 15, 2017 | 02:03 PM
  #957
NSXRebel's Avatar
NSXRebel
so many pages to go thru, I gave up, but is anyone running 16x8 steel wheels with OEM tires 196/55? Kinda want a bit of a stretched look. I have black oem wheels and wanna go with the murdered out look so not really wanting expensive alloys.
Old May 17, 2017 | 08:51 AM
  #958
miniuy's Avatar
miniuy
I'm running 16x8 on 205/55.
I don't want them too streched.
Old May 17, 2017 | 09:17 AM
  #959
NSXRebel's Avatar
NSXRebel
I also want to see what the 195/55 looks like since I have some rubbing on the rear and this could be the solution.
Pics please?
Old May 18, 2017 | 08:13 AM
  #960
miniuy's Avatar
miniuy
Pics please?
Old Jun 3, 2017 | 01:44 AM
  #961
Shartak's Avatar
Shartak
I see some fitment experts here
how about that :
16x8 ET 33 on a R53, will it fit ? I don't want to mess with camber too much, but can do some.
and if ET33 is too easy to fit, what ET would be better between Et22 and Et 27 ?
Because I found wheels that a really like, and they can be machined to the desired ET between 22 and 27.
cheers guys !
Old Jun 3, 2017 | 04:36 AM
  #962
CSP's Avatar
CSP
offset?
Old Jun 3, 2017 | 06:12 AM
  #963
mini coop's Avatar
mini coop
how about that :
cheers guys !
The wheels you listed will fit fine and will appear flush with the arches. At 8" wide the tire will begin to extend beyond the arches with a 27et and definitely beyond and outside the arches at 22.
Old Jun 3, 2017 | 09:43 AM
  #964
MADNESSray's Avatar
MADNESSray
Pogea Racing XCut500 18x8 et27 running 215/35r18 with only slight rubbing in the rear over very severe elevation changes. conservative drop on NM springs (and the ride is buttery smooth to be honest)
Old Jun 4, 2017 | 02:38 PM
  #965
GEdwardJ's Avatar
GEdwardJ
TRMotorsport C4
17X8 w/45mm offset all around
Bridgestone Potenza RE71r 215/45
Stock ride height
No Rubbing, just barely.
Old Jun 4, 2017 | 04:01 PM
  #966
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Originally Posted by GEdwardJ
TRMotorsport C4
Stock ride height
Nice! I'm considering those in the gray color.
Any more pictures?
Where do they rub?
Old Jun 4, 2017 | 04:19 PM
  #967
GEdwardJ's Avatar
GEdwardJ
Any more pictures?
Where do they rub?
Sorry, I wasn't clear, they just barely don't rub. I feel like if I lowered my car I'd have to do some fender modifications. But at stock ride height, even with my bigger than an average bear self and a passenger onboard, taking turns at higher than suggested speeds I've had no rubbing.
Old Jun 5, 2017 | 06:35 AM
  #968
miniuy's Avatar
miniuy
Originally Posted by csp
offset?
et30
Old Jul 30, 2017 | 11:19 AM
  #969
the_dude_abides's Avatar
the_dude_abides
Great thread all, thanks for the info.
So far as I can tell, an 18x8 will fit just fine, but it's the offset in question. Stock offset for my stock 17x7s on my R55 is 48. It _looks_ like I can get away with an 18x8 ET48 as well, with 225/35/18 tires and no interference with the suspension/fenders.
Can anyone verify this setup will fit fine with no rubbing (stock ride height) and/or if I lower it later on? I'm fine with camber adjustments to help the fitment later (plan on doing c/o's anyhow).
I've been using this fantastic site to calculate size possibilities:
https://www.wheel-size.com/calc/?whe...cl=30mm&sr=0mm
Old Aug 9, 2017 | 06:25 PM
  #970
MoFasterMo's Avatar
MoFasterMo
AODHAN: AHO2
17x8
offset: +35
205/45R/17
Stock height
No rubbing ever
Old Aug 10, 2017 | 05:59 AM
  #971
xentar's Avatar
xentar
Wheel/Model: MOMO Revenge
Offset: 45
Wheel Size: 18x8
Tire Size: 205/40/R18 (Michelin Pilot Sport A/S3)
Suspension: Stock
Camber Settings: Stock
Rubbing: No
Old Aug 16, 2017 | 10:28 AM
  #972
900exdriver's Avatar
900exdriver
Old Aug 16, 2017 | 10:30 AM
  #973
CSP's Avatar
CSP
^^ What are those? Specs?
Old Aug 16, 2017 | 10:40 AM
  #974
900exdriver
949 6ul's. 15x8 et36. 8mm spacers up front and 5 in the back
Old Sep 20, 2017 | 08:51 AM
  #975
Minibeagle's Avatar
Minibeagle
Did you need the front spacers because of rubbing issues? If so, where were you rubbing in front?
What about the spacers in the rear? Again, just for looks or rubbing?
What size tire are you running on that setup?
