BigBoy ported intake setup and 65mm tbody ( awesome gains )
For SaleEngine - Intake/Fuel
Price
$300• OBO • Trade
- Location Oakcreek, WI, 53154, USA
- Condition Used
I'm selling a complete upgraded intake setup for your r53. This helps prevent cyl#2 from going lean thx to the port n polishing and air path corrections. It also adds a nice bump in power as well as allows you to run a 19% pulley and not have iat's issue even with using stock intercooler. The ceramic coating also helps prevent heat soak issues.
the throttlebody is brand new and since porting , polishing and anti heat ceramic coating the intake components they have not been used.
the intake manifold, both ic horns along with the boost tube have been ported and air paths corrected and the throttlebody is a 65mm and has already been modified to install without any other modifications. The stock hose has also been stretched to fit.
I'm selling everything together as a set for 360$ SHIPPED ONLY !!!!!
Ecs sells this throttlebody for almost 200$ ALONE !!!
IVE sold numerous of these ported setups and every buyer has had nothing but grwat things to say about the gains befor and after. I ran this same setup on my personal car until I went FULL aftermarket.
pm or respond to this post.
Stay safe N MOD on !!!!!
you want the stuff ?.
shipping on this sized box and weighs, depending on area ( cali usually is more ) is between 45-75$..
Time is money guys and gas isn't free either.....
so 360$ SHIPPED TO LOWER 48 !!!
The ported manifold also helps prevent cyl#2 from going lean as there is a factory flaw in the design of the manifold that causes that. I correct that also.
the larger throttlebody too people claim to get upto 2psi more using it but it just allows for more flow and to move the powerband up the rpm range to a move useable spot.
then the costing helps hold the heat in to keep underhood temps down and also to give your car a much classier look when the engine is shown.
your getting by far the best deal on these parts.
look what ecs sells this throttlebody for by its self...cmon now
Please message once your ready to purchase .
you want it all , 360$ shipped to lower 48$ , no i wont go lower either, sorry...
