2011 R55 Clubman S, 6MT, well maintained, great condition
2011 Mini R55: "Mk II" Mini Clubman
  • 2011 Mini R55: "Mk II" Mini Clubman - 2011 R55 Clubman S, 6MT, well maintained, great condition - Used - VIN WMWZG3C52BTY30215 - 93,000 Miles - 4 cyl - 2WD - Manual - Black - Phoenix, AZ 85022, United States
    $7,700
    • OBO
  • Location Phoenix, AZ, 85022, USA
  • VIN WMWZG3C52BTY30215
  • Mileage 93,000
  • Engine 4 cyl
  • Drive Type 2WD
  • Transmission Manual
  • Exterior Color Black
Mini Clubman Cooper S
Manual transmission
Midnight Black (A94)
Carbon black leather (T8E1)
Production date: September 26th 2010
Asking $9500 OBO
Price dropped to $7,700
I've owned this car for three years, but our family needs have changed and I'm out of parking spaces. As you can see below it has received a lot of attention in the last three years. The exterior is in great shape for a daily driver with no major paint issues and a few minor dings. The interior is in excellent condition. I performed the work for clutch/trans, brake/rotor replacement, exhaust swap, all suspension work, cosmetic bits, and most regular maintenance. All other work performed by Eurosport in Phoenix, AZ. Records available. Title in hand.
  • Currently 93,000 miles, purchased October 2020 with about 75,000 miles. CA car until 2020, AZ since then.
  • Oil change with 5w-40 Pennzoil Platinum Euro Synthetic and Purolator filter every 5,000 miles or less (due at 95,500mi)
  • Foam air filter cleaned every 12 months (just cleaned)
  • Cabin filter replaced every 12 months (just replaced)
  • Battery replaced within last 12 months
Mods
  • Alta foam intake filter
  • WMW intake silencer bypass
  • Forge silicone intake noisemaker bypass
  • Powerflex front control arm bushings
  • SuperPro front swaybar bushings
  • NM lower engine mount bushing insert
  • Milltek catted downpipe
  • JCW catback
  • Prototype-r Stage 1 tune
  • Mfactory helical limited slip differential
  • Bilstein B6 shocks/struts
  • Ireland Engineering 22mm adjustable rear swaybar
  • Porterfield R4-S brake pads
  • EBC slotted/dimpled front and rear rotors
  • ECS stainless brake lines
  • Cravenspeed cellphone mount
  • Cravenspeed shift ****
  • Cravenspeed shift well cover
  • Cravenspeed black acetyl handbrake handle
  • Cravenspeed stubby antenna
  • Cravenspeed dipstick
  • Custom black leather with red stitching handbrake cover
  • Mini OEM Cooper S rubber floor mats
  • 205/50ZR-16 Continental ExtremeContact DWS 06 Plus tires
  • All OEM exhaust parts available
Maintenance
75-80k miles
  • New OEM clutch, flywheel, throw out bearing, clutch fork pivot pin
  • New transmission mount
  • New OEM Getrag transmission axle seals
  • Installed MFactory LSD w/ new differential bearings
  • Filled transmission with Red Line MTL
  • New engine rear main seal
  • New engine drive belt
  • Replaced coolant reservoir
  • Installed WMW intake silencer bypass
  • Installed OEM updated turbo bypass valve
  • Installed Powerflex front control arm bushings
  • Installed NM lower engine mount bushing insert
  • Replaced all 4 jack pad mounts
80-85k miles
  • New timing chain
  • New valve cover
  • Valve carbon cleaning
  • New front main seal
  • New top engine mount
  • Installed Milltek catback and stage 1 tune
  • Installed Ireland Engineering 22mm adjustable rear swaybar
85-90k miles
  • Installed Conti DWS tires
  • Installed Porterfield R4-S brake pads
  • Installed EBC slotted/dimpled front and rear rotors
  • Installed ECS stainless brake lines w/ Motul fluid
  • Installed rear lower bumper grille (it was missing)
  • New water pump
  • New coolant pipe
90-93k miles
  • Installed Bilstein B6 shocks/struts
  • New front strut top mounts, rear mount bushings, front/rear bump stops, front rear shims/pads, rear bellows, front/rear lower hardware
  • New passenger side axle
  • New antenna housing and stubby antenna
  • Installed Meyle HD front swaybar links
Old Feb 4, 2024 | 02:24 PM
mrjosh43's Avatar
mrjosh43
Still available and running strong. Price dropped to $7,700.
