NM Engineering / Neuspeed RSe05 wheels / Michelin Pilot Sport All Season 4
Wheels and Tires/Axles
  • Wheels and Tires/Axles - NM Engineering / Neuspeed RSe05 wheels / Michelin Pilot Sport All Season 4 - Used - 2014 to 2023 Mini F56: Mini Hatch/Hardtop - 2014 to 2023 Mini F55: 5-door Hatch - Hartford, CT 06101, United States
    $1,000
    • OBO
  • Location Hartford, CT, 06101, USA
  • Compatibility
Make Model Year
Mini F56: Mini Hatch/Hardtop 2014 - 2023
Mini F55: 5-door Hatch 2014 - 2023
This is a set of 4 NM Engineering RSe05 wheels in satin black, with Michelin Pilot Sport All Season 4 tires. Installed for aprox 5000 miles on my 2021 Mini Cooper S. Used in fall/winter. My Mini was lowered around 1" on JCW coilovers and I already had a set of 225s mounted that took care of any clearance issues, but I imagine these might rub for a day or two on the inside upper portion of your rear plastic arch. This happens on the inside, maybe 1-2mm, and did not cause any issue for me.
17x7.5, +40, 5x112, 66.5 CB
225/45/17
In case anyone is not familiar with these wheels - they are designed exclusively for the F56 platform and as such they are hub centric (no centering ring required), they use the factory center cap (RS center cap is included in this sale), and they utilize the factory lug bolts - not aftermarket type lug bolts.
This set is in great condition. No curbage or dings. The satin finish has some areas where you can see some rubbing/burnishing, and some light scratch marks, but not noticeable from 5 feet away.  Tires have even wear and all 4 are above 7/32". These were mounted and balanced by NM Engineering and they DO NOT have TPMS.
Looking for local pickup in central CT. I do have boxes but shipping would be hundreds of dollars....
