Hotchkis Sport Rear Camber Links for R50 R52 R53
Steering/Suspension
  • Steering/Suspension - Hotchkis Sport Rear Camber Links for R50 R52 R53 - Used - 2002 to 2008 Mini R50: "Mk I" Mini One & Cooper - 2002 to 2008 Mini R52: "Mk I" Mini Convertible - 2002 to 2008 Mini R53: "Mk I" Mini Cooper S - Mountain View, CA 94043, United States
    $165
    • OBO
  • Location Mountain View, CA, 94043, USA
  • Compatibility
Make Model Year
Mini R50: "Mk I" Mini One & Cooper 2002 - 2008
Mini R52: "Mk I" Mini Convertible 2002 - 2008
Mini R53: "Mk I" Mini Cooper S 2002 - 2008
Hotchkis 13800 Sport Rear Camber Link Kit for Mini Cooper 2002 - 2008 R50 R52 R53
Hotchkis H-Sport Rear Camber Links are perfect for lowered Minis. They have an adjustment range from zero to negative four degrees for increased rear grip. The Sport Rear Camber Links are designed and tested to suit any street or track environment.
Each Link is simply adjusted by loosening the lock nuts and then rotating the hex center for more or less camber. The Hsport Camber Links themselves are made up of two tubular steel outer arms with a billet aluminum hex center. The polyurethane bushings can be greased by utilizing the zerk fittings at each end. Durable, yet highly functional, the Sport Camber Links give you the freedom to set your Mini'­s rear camber at any setting.
Now come all black for a cleaner look.
Old Jul 2, 2022 | 11:02 PM
Bhob13's Avatar
Bhob13
Interested sir
