FS: R50/R53 Godspeed Mono Maxx Coilovers (40 way adj dampening coil overs)
Steering/Suspension
  • Steering/Suspension - FS: R50/R53 Godspeed Mono Maxx Coilovers (40 way adj dampening coil overs) - Used - 2002 to 2006 Mini R53: "Mk I" Mini Cooper S - 2002 to 2006 Mini R50: "Mk I" Mini One & Cooper - Saint Augustine, FL 32086, United States
    $550
  • Location Saint Augustine, FL, 32086, USA
  • Compatibility
Make Model Year
Mini R53: "Mk I" Mini Cooper S 2002 - 2006
Mini R50: "Mk I" Mini One & Cooper 2002 - 2006
PM me for quickest response!
For sale, a set of lightly used Godspeed Mono Maxx coilovers for R50/R53 models.  I had these on my 2006 R53 for a few thousand miles.  I put the car back to stock before I sold it, which is why these are up for sale.  They may be used, but they are in great shape with only cosmetic wear and scratches.  These were used in Florida and not exposed to any winter or harsh weather.  I definitely enjoyed these, and they road like much pricier coilovers!
They come exactly as pictured; All four corner assemblies, with coilover wrench, allen tool to remove dampening adj if needed, & sticker.  I do not have the Godspeed end links as they stayed on the car when I sold it (depending on your ride height, you can use your stock end links or buy cheap aftermarket adjustable links.)
Features:
  • 40 precise levels of damper adjustment
  • Mono-tube Design With Anodized Shock Body
  • Lightweight aluminum shock components and T7075 forged aluminum / carbon steel brackets.
  • 52 mm carbon steel shock body with a 44 mm internal piston.
  • Independent ride height and spring pre-load adjustments.
  • Italian IP F.A made shock oil with a high viscosity index.
  • Front camber adjustable plates are included.
Godspeed sells these new for $990; https://godspeedproject.com/mini-coo...coilovers.html
$550 picked up in Saint Augustine Florida, or
$600 shipped within the U.S.
The attached R53 image was my Mini with these coilovers installed
Again, please PM me for quickest response.  Thanks for looking!
