2010 Mini Cooper S Manual
2010 Mini R56: "Mk II" Mini Hatch/Hardtop range
  • 2010 Mini R56: "Mk II" Mini Hatch/Hardtop range - 2010 Mini Cooper S Manual - Used - VIN WMWMF7C52ATX43207 - 138,000 Miles - 4 cyl - 2WD - Manual - Hatchback - Silver - Clifton, VA 20124, United States
    $7,600
    • OBO
  • Location Clifton, VA, 20124, USA
  • VIN WMWMF7C52ATX43207
  • Mileage 138,000
  • Engine 4 cyl
  • Drive Type 2WD
  • Transmission Manual
  • Vehicle Type Hatchback
  • Exterior Color Silver
Hello Mini community,
I bought this R56 in May as my temporary car until I find a replacement for my E39 M5. I bought this Cooper S because most of the known issues were addressed, plus it has a very detailed maintenance history. It has been serviced and maintained at a BMW/Mini service center. I have finally found the car I want, therefore, selling my R56. It doesn't have any issues. The engine was replaced by Mini of Baltimore when it was at 84,760 miles. The current mileage on the car is 138,000, which comes to 53,240 miles on the current engine. The engine was replaced because of bent exhaust valves. I have all the paperwork with details.
Due to the lien transfer, Carfax shows five owners but actually, there are four owners, including me. It comes with 2 Key fobs, has a leather interior, Harmon Kardon Sound, Panoramic Sunroof, and Bluetooth. I would rate the exterior at 7 and the interior 8+. One item I would like to disclose is while replacing its valve cover gasket, the vacuum hose got cracked which I have repaired using some sealing tape and silicon gasket maker. There is no vacuum leak.
My asking price is $7600. The car is registered in VA. Below is its maintenance history; I am sure I am missing a few items:
30-May-21 137890 Valve Cover Gasket
17-May-21 137880 Rear Tires - Michelin
22-Mar-21 137275 Oil Service/Change
11-Feb-21 136670 Satellite Radio Replaced, Fuse Box SPEG High, and Speed Sensor Replaced
28-Oct-20 135800 Oil Service
28-Oct-20 135800 Battery Replaced and Registered
28-Oct-20 135800 Front Struts and Mounts
22-May-20 130960 Oil Service
15-Oct-19 124500 Trunk Latch Replaced
5-Nov-18 115210 Standard Scope Service, Oil Change and Air Intake Filter
16-May-17 97300 Footwell Module - Replaced FRM
16-May-17 97300 Horn Replaced
16-May-17 97300 Oil Service
29-Nov-16 92160 High Pressure Pump
03-Oct-16 90585 Oil Service
8-Mar-16 84760 Coolant Thermostat
8-Mar-16 84760 Thermostat Housing
8-Mar-16 84760 Clutch and Flywheel
8-Mar-16 84760 Replaced Engine and all associated parts
Old Jul 2, 2021 | 08:49 AM
stubornn's Avatar
stubornn
Friday bump.
