FS: R56 N14 engine parts and LSD transmission
2009 Mini R56: "Mk II" Mini Hatch/Hardtop range
  • 2009 Mini R56: "Mk II" Mini Hatch/Hardtop range - FS: R56 N14 engine parts and LSD transmission - Americus, GA 31709, United States
    Expired
    Expired
    Expired
  • 2009 Mini R56: "Mk II" Mini Hatch/Hardtop range - 42mm Alta K03 turbo - Engine - Intake/Fuel - $250 - Americus, GA 31709, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
  • 2009 Mini R56: "Mk II" Mini Hatch/Hardtop range - PLM catless downpipe 2.5" - Engine - Exhaust - $100 - Americus, GA 31709, United States
    Expired
    Expired
    Expired
  • 2009 Mini R56: "Mk II" Mini Hatch/Hardtop range - AEM intake - Engine - Intake/Fuel - $300 - Americus, GA 31709, United States
    Expired
    Expired
  • 2009 Mini R56: "Mk II" Mini Hatch/Hardtop range - Reman Head - Engine - Internals - $600 - Americus, GA 31709, United States
    Expired
    Expired
    Expired
    Expired
    Expired
10/6/21 update...complete part out. Check back here for more parts before I scrap it.
The Getrag 6 speed has an MFactory helical LSD installed.
The engine has a newly rebuilt head, new Facet thermostat, Facet ignition coils, VNE oil pump, Forge hoses, CP pistons and AEM intake.
The car has 112k miles but there is less than 20 miles on many of these parts.
I believe there is an issue with the block. It currently runs and drives but uses coolant and eventually starts to overheat.
Buyers are welcome to inspect and try before you buy.
I have added videos of the startup and engine running as parts are now being removed.
If you are looking for something in the engine bay that's not listed, message me.
I will be adding to this listing, prices are OBO.
Videos-
https://drive.google.com/file/d/11ki...ew?usp=sharing
https://drive.google.com/file/d/1263...ew?usp=sharing
https://drive.google.com/file/d/11q_...ew?usp=sharing
Picture Title Part Category Price Part Description
6 speed manual transmission with Mfactory LSD Drivetrain $700 GS6-53BG
Transmssion with LSD, fits 07-10 cars for sure.
The Mfactory MF-TRS-05MIN limited slip
fits ALL years 07-14, and could be removed.
The only difference is the newer cars use a different
flywheel, but this one fits those engines.
(Clutch, axles, starter, shift linkage are the same 07-14.)
Carillo CP forged pistons SC7515 Engine - Internals $400 Standard 77mm, 10.5 compression ratio
42mm Alta K03 turbo Engine - Intake/Fuel $250 Germany made, Borg Warner K03.
This is supposed to be an Alta 42MM
You can see the machined billet turbine wheel.
There is some visible wear, working when removed.
PLM catless downpipe 2.5" Engine - Exhaust $100 Hi flow downpipe 2.5"
Heat wrapped, new oem clamp.
Add $50 for both o2 sensors.
one is a new NTK.
Includes spacers.
AEM intake Engine - Intake/Fuel $300 AEM ram air cold air intake
Like new Bosch MAF add $70
Forge turbo to intercooler hose, black Engine - Intake/Fuel $80 Hot side hose, 'resonator delete' price includes shipping.
Forge noise delete intake hose, blue Engine - Intake/Fuel $50 Cold side intake hose, deletes noise maker and metal
coupling.
Price includes shipping.
Reman Head Engine - Internals $600 Done by the most reputable machine shop in the area, Benning Auto Parts in Columbus. Has timing holder tools in place.
Timing tools and ARP hardware included.
Old Feb 11, 2021 | 09:34 AM
Yoshimura 1's Avatar
Yoshimura 1
Will you be parting with the wheels
Old Feb 11, 2021 | 11:26 AM
zrickety's Avatar
zrickety
No, sorry. I'm looking to Honda K-swap the car.
Old Feb 11, 2021 | 12:15 PM
al b's Avatar
al b
you sure it is the block and not the thermostat housing or a oring? Mine was going down and it turned out to be the housing was leaking.
Old Feb 11, 2021 | 12:49 PM
zrickety's Avatar
zrickety
Yes, thanks. I replaced the housing, the pipe, the o-rings, etc etc. On top of that there is a P1497 with new gaskets, hoses and valve cover. I'm done throwing money at this engine.
Old Feb 11, 2021 | 01:07 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I'm sorry you were never able to get it right. The K-swap sounds interesting...
Old Feb 11, 2021 | 01:17 PM
zrickety's Avatar
zrickety
Thanks. It will probably take another year to get it done but I'm motivated. I have seen it done to a few 1st gens, but not 2nd.
Old Feb 11, 2021 | 04:02 PM
Yoshimura 1
Can I see pictures of the turbo
Old Feb 11, 2021 | 05:28 PM
zrickety's Avatar
zrickety
Yes, I'll post them for you tomorrow.
Old Feb 11, 2021 | 07:26 PM
Yoshimura 1
Thanks I'll be waiting
Old Feb 12, 2021 | 10:40 PM
troyegly's Avatar
troyegly
K Swap now there is a good idea, sounds very cool! Which K?
How much for the forge on the hot side of the intercooler?
TY
Old Feb 13, 2021 | 06:30 AM
zrickety's Avatar
zrickety
TY
Sending you PM.
Old Feb 13, 2021 | 06:37 AM
zrickety's Avatar
zrickety
Edit- Have updated with some pics and videos.
Old Feb 13, 2021 | 10:07 AM
zrickety's Avatar
zrickety
Pics are up.
Old Feb 13, 2021 | 11:24 AM
zrickety's Avatar
zrickety
AEM intake is pending sale.
Old Feb 13, 2021 | 04:26 PM
Yoshimura 1
Trying to find specs on that particular turbo
Old Feb 14, 2021 | 06:19 AM
zrickety's Avatar
zrickety
Germany made K03, previous owner said 287 hp/ 307 ft-lbs on this setup.
Old Feb 14, 2021 | 08:10 AM
zrickety's Avatar
zrickety
Transmission is listed on ebay for 10 days. Forum price here is better.
Old Feb 15, 2021 | 08:49 AM
zrickety's Avatar
zrickety
Updated with sold parts.
Old Feb 15, 2021 | 11:41 AM
Yoshimura 1
Still waiting the info
Old Feb 15, 2021 | 01:37 PM
zrickety's Avatar
zrickety
Got the turbo off and added more pics above. You can see the machining on the wheel. I have attached a pic from Alta for comparison.
My turbo
Alta pic
ALTA Billet 56 Turbo Upgrade | PERRIN Performance
Old Feb 15, 2021 | 02:48 PM
Yoshimura 1
Pm'd you
Old Feb 15, 2021 | 04:38 PM
Yoshimura 1
Pm'd you
Old Feb 15, 2021 | 06:36 PM
zrickety's Avatar
zrickety
Pm'd you
I tried to reply to your message but your mailbox is full.
The car was running and driving, there were no turbo related engine codes. I don't think it needs a rebuild.
I took some measurements and estimate shipping at $40 with FedEx. I'll include the copper washers and bolts that go to the cooling and oil lines. Also the exhaust manifold gasket was new and torqued properly, you could probably reuse that too.
Ricky
Old Feb 16, 2021 | 06:07 AM
zrickety's Avatar
zrickety
Have updated transmission info for those interested.
