Suspension IE camber plates
Old Mar 21, 2007 | 07:52 PM
MRmidge's Avatar
MRmidge
IE camber plates
Does anyone know if the Ireland Engineering fixed camber plates change the ride height of the car. Or, with stock suspension does it retain stock height.
Thanks,
Brian
Old Mar 22, 2007 | 06:33 AM
THE ITCH's Avatar
THE ITCH
It will retain stock height. It may take a day or two for the front suspension to settle but when it does you will be back to stock. Ireland uses a bearing from BMW that sits in urethane/rubber and the ride and noise should be close to stock.
Steve
Old Mar 22, 2007 | 06:57 AM
justintime's Avatar
justintime
Steve
the rides close to stock?! -hits head-
Old Mar 22, 2007 | 07:14 AM
AliceCooperWA's Avatar
AliceCooperWA
Yea...similar to stock mounts, but beefed up. They are stronger than stock, they have slightly more rubber and thicker metal. The car will be almost half an inch higher when you first install them, but they will settle. It will definately not make the ride any rougher.
Old Mar 22, 2007 | 08:11 AM
inimmini's Avatar
inimmini
Exactly my experience. In fact, the ride is bit more compliant with the IE fixed plates vs. stock.
Old Mar 22, 2007 | 12:44 PM
THE ITCH's Avatar
THE ITCH
justintime
Please note that if you install some of the well know adjustables, like the Helix, you will be raising the front end approx 1/4-3/8. Any of the solid ball mounts will transmitt more NVH than the ones mounted in urethane/rubber.
Steve
Old Mar 22, 2007 | 12:56 PM
justintime's Avatar
justintime
justintime
Steve
ah I didnt mean ride height my bad, I thought you meant the ride wouldnt change much in terms of performance Im saving for the fixed camber plates right now.
Old Mar 22, 2007 | 02:05 PM
MRmidge's Avatar
MRmidge
Awsome thats just the information i was hoping for. Fixed plates are now on the to buy list.
Old Mar 22, 2007 | 03:02 PM
Grey Shade's Avatar
Grey Shade
I am planning on buying them also so let me know how the install goes when you get them. good luck.
Old Mar 22, 2007 | 03:42 PM
Crashton's Avatar
Crashton
I'm thinking very hard about buying the IE adjustable camber plates. Nice to know the ride hight will remain stock & the ride is good. Sounds like a win-win situation.
Edit.... I have an R53, stumbled on the R56 forum by mistake. I'd guess the same goes for the R53 plates too.
got_mini?
Oct 7, 2015 02:12 PM
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
