Suspension Lowering Springs
Old Mar 31, 2007 | 10:23 PM
  #51
msh441's Avatar
msh441
OK, one last question for you Ryephile:
In the Helix post that popped to the top of the forun today, this comment jumped out at me: "The biggest problem was fitting the stock swaybar drop links. With the new angles of the subframe, it looks like lowered cars will have an issue of the drop link smashing against the lower control arms."
Granted they were installing the Helix coilover setup from an R53 into their R56, but as you can imagine it still raised some concerns. I would imagine that H&R would check their stuff out before releasing to the public, but... just for my peace of mind: Have you seen any evidence of the H&R springs allowing the drop link and lower control arms to come in contact with each other?
Old Apr 1, 2007 | 05:06 PM
  #52
Ryephile's Avatar
Ryephile
Not sure what Helix is talking about has anything to do with "just" lowering springs. If the stock suspension bottoms out, it doesn't matter if it has stock springs or aftermarket, it's bottomed out. With a coilover, the position of the R53 drop link on the shock body is probably different than the R56, hence the drop link tweak needed. If you're planning on using R53 stuff, keep an eye out for small tweaks like that, otherwise, no concern needed.
Old Apr 24, 2007 | 04:25 AM
  #53
dxl007's Avatar
dxl007
Any one know if these are the same springs that you guys are talking about from the UK?
http://www.tirerack.com/suspension/s...452&perfCode=S
Old Apr 24, 2007 | 07:47 PM
  #54
ygblat's Avatar
ygblat
Check it, Dan's hooking it up!
https://www.northamericanmotoring.co...04#post1492404
Old Jun 19, 2007 | 10:12 AM
  #55
hanswang123's Avatar
hanswang123
hey guys i'm trying to decide between the H&R lower springs and the H-Sport springs for my 06 mini (non-s) but i don't know which ones are better.
someone help me out lol
Hans
Old Jun 26, 2007 | 05:40 PM
  #56
mikeg4572's Avatar
mikeg4572
I got my springs yesterday! They are going on Friday. Will post before and after pics!
Old Jun 26, 2007 | 06:14 PM
  #57
Ryephile's Avatar
Ryephile
Congrats! You're going to love them!
Old Jun 26, 2007 | 06:29 PM
  #58
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
https://www.northamericanmotoring.co...d.php?t=105322
Mike: If you are doing this yourself the link above might help! Let me know if I can help in anyway further. Thanks again for the biz-nez!
Old Jun 26, 2007 | 06:32 PM
  #59
ADAMSALTAMINI
hanswag123: Just my two cents I have had the H&R's on both the R53 and the R56 (the ALTA springs for the R53 were an Adam revised H&R made by H&r) I got to tell you, you will love them! Period hands down! Let me know if I can ever help. Plus the DIY above is nearly identical for the R53, hope that helps as well. Thanks!
Old Jun 28, 2007 | 03:34 PM
  #60
mini matt's Avatar
mini matt
I asked this in the "Howard get's dropped" thread as well but.......
When you guys installed the springs did you find that the front sway bar endlinks were long enough that the sway bar mount was still parallel to the endlink rod or are adjustable (longer) end links necessary ?
Old Jun 28, 2007 | 04:34 PM
  #61
snkbte's Avatar
snkbte
Matt. Everything bolted back together fine. The end of the swaybar(where the link attaches) is pretty much centered between the lower control arm and the inner wheel house lip,with no possible way for it to come in contact with either part. Hope this answers your question.
Old Jun 29, 2007 | 03:22 AM
  #62
mini matt's Avatar
mini matt
Thanks snkbte. It's good to know the clearance is good since that was my biggest concern.
What I'm also curious about is; Since the coilover assembly is going to sit deeper in the tower because of the shorter coil spring and because one end of the link connects to it (the assembly) and the other to the sway bar end isn't this going to decrease the amount of downward pressure (preload) on the sway bar and therefore it's effectiveness ? If this is the case, is the decrease in the sway bar's effectiveness noticeable or so little it's not worth worrying about?
Although my background is in mechanics I don't have any experience with lowering cars with coilovers so sorry if this question(s) seems elementary.
Old Jul 29, 2007 | 12:48 AM
  #63
ernestazuela's Avatar
ernestazuela
any other lowering springs brand for my R56 aside from H&R?
Old Jul 29, 2007 | 12:50 AM
  #64
ernestazuela
Old Jul 29, 2007 | 04:58 PM
  #65
msh441's Avatar
msh441
Sure... theres Eibach, and H-Sport... and M7 tuning carries some (though I'm not sure if they're making them, or re-branding or someone elses springs). Webb Motorsports and Alta both carry the H&Rs... I'm sure there are more out threre, too.
Old Jul 29, 2007 | 05:40 PM
  #66
mikeg4572's Avatar
mikeg4572
I have not seen anything for sale at this time except for H&R's. Where are you finding H-sports and Eibachs for sale?
Old Jul 29, 2007 | 07:06 PM
  #67
spam052's Avatar
spam052
does anyone know who's selling the springs now. it seems everyone is on a backorder wich sucks. i just got my new tenzo wheels and it be nice to lower the car.
patsum
26
May 29, 2021 06:29 PM
smdmini
Oct 7, 2019 06:05 AM
Supertractor3
Apr 7, 2017 11:16 AM
ej
Nov 17, 2015 09:21 PM
Sep 2, 2015 11:15 AM
