North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   Suspension (https://www.northamericanmotoring.com/forums/suspension-69/)
-   -   Suspension Who's got a nicer rear? (https://www.northamericanmotoring.com/forums/suspension/78369-whos-got-a-nicer-rear.html)
obehave Sep 5, 2006 06:57 PM
Although there hasn't been a ot of exposure to it yet it appears there is a redesign to the rear suspension in the MINI.
Information is a bit sparse:
Here's a bit
The central-arm rear axle is new to MINI and unique in this segment. Its longitudinal track control arms are made of aluminium that reduces weight by 6 kilos over the former model.
http://www.mini2.com/images/zandvoor...600_r56_HA.jpg
Old rear suspension
http://www.bmwworld.com/pics/mini/5014_832.jpg
http://www.mini2.com/images/zandvoor...cal/095607.jpg
What's the take? Better or worse? What are the advantages, if any, of the new rear suspension?
kenchan Sep 5, 2006 07:07 PM
it could have all sorts of goodies piece by piece, but i would really
need to drive it as a whole with all the parts combined to determine
whether that's better or worse.
SB Sep 5, 2006 07:13 PM
Is it just the rear central arm axle that changed? I'm assuming that is the main component that is black in the picture. Sometime during 06 the lower control arms changed and they look similiar to the ones in the picture. More squared off at the edges instead of the pressed together looking ones. Though they are still some type of steel.
elprofe Sep 5, 2006 07:16 PM
I got mine for two hundred bucks at steve's auto clinic. Never thught i was saving so much weight .....eh!
modified mini Sep 5, 2006 10:58 PM
Keyra Augustina does.:thumbsup:
TonyB Sep 5, 2006 11:20 PM
So much for my straight exhaust being unique... I like that.
6 kilos (13+ pounds) in savings on the control arms?! Maybe as a whole for the rear, but not just for the arms. A pair of stock control arms, on an '03 at least, weighs 6.8 lbs. The Alta's, which are quite light, weigh 3.8 pounds, or a 3 pounds delta, per pair...
onasled Sep 6, 2006 04:08 AM
... I'm not seeing a difference here ...?
I know the trailing arms are aluminum, but the complete design looks to be the same. Am I missing something?
markldriskill Sep 6, 2006 04:49 AM
re: From whence the weight loss?
Are the spring and damper assy's shorter? In the drawing they appear to not extend as high as my '04. :confused:
Also, could they be counting (unfairly, IMHO:sly: ) the loss due to single exhaust?
DrPhilGandini Sep 6, 2006 05:47 AM
I know it's a poor drawing, but I don't see adjustable control arms, just fixed length ones like we have. The lower outside bolt might be in an eccentric like the 05/06s but even that isn't clear in the image.
That's a lot of weight to save from 4 control arms - there must be something else.
cheers,
onasled Sep 6, 2006 07:11 AM
cheers,
No, the weight saving is not the control arms, but rather in the new aluminum trailing arm
TonyB Sep 6, 2006 08:46 AM
Ah, that would do it then. The language provided said control arms... I guess they did their homework, but my first inclination would be that steel might be desirable on such a piece for strength concerns as it sees a fair amount of force.
DrPhilGandini Sep 6, 2006 08:50 AM
onasled: is your sig photo a Porsche 917? I love it!
Rick-Anderson Sep 6, 2006 09:19 AM
The brake calipers in the sketch look quite different than that of the current models. Is this only a sketch variation or have the brakes actually been changed? I like the straight-through exhaust. It might sound like a real British car now. :thumbsup: Plus this should open the door to less expensive aftermarket versions.
Morris9982 Sep 6, 2006 09:36 AM
I wonder where the battery is located in the new model...
obehave Sep 6, 2006 10:59 AM
cheers,
If you look closely the hubs appears smaller as well.
Motor On Sep 6, 2006 11:19 AM
I'm betting with the larger bonnet and engine bay they made some room, but hatis purely a hunch.
From looking at the photos and how everything lines up, it appears that if you want to do a sway bar in the 07+ that you'll probably be having to move the exhaust in order to move the subframe, which is going to make the simple mod more involved.
As far as which is better I think we'll just have to wait a few months, but as much as I'm not fond of many of the changes I also highly doubt BMW would make the car's impressive handling (and possibly largest selling feature) any worse so I'd expect it to be at least equal.
onasled Sep 6, 2006 11:39 AM
908/3 :thumbsup:
