Suspension H&R Xmas Deal- 3 sway bars for the price of 2
Old Dec 22, 2004 | 07:10 PM
MINImotor's Avatar
MINImotor
Just wanted to let NAM memebrs knows of a little deal I stumbled onto today-
H&R Springs is including a free 18mm rear bar as an option for anyone buying their Sport Swaybar set for the MINI. You get:
27mm front bar
19mm Two-way adjustable rear bar
Free 18mm rear bar (while quantities last)
Teflon impregnated bushings
I ordered a set ASAP this morning for a little Christmas bliss....
I love free stuff.....
Old Dec 22, 2004 | 09:52 PM
minibobinva's Avatar
minibobinva
Sounds great!
Where did you order them?
thanks,
Bob
Old Dec 22, 2004 | 10:18 PM
MINImotor's Avatar
MINImotor
www.hrsprings.com
From H&R Springs- 1-888-827-8881.
Tire Rack www.tirerack.com also carries them.
Old Dec 22, 2004 | 10:21 PM
kenchan's Avatar
kenchan
18mm, 19mm, front swaybar...hummmmmmmmm.....
Old Dec 23, 2004 | 06:56 AM
KevinR's Avatar
KevinR
Apparently I'm not hitting on all cylinders this morning. Why would someone want 3 sway bars?
Old Dec 23, 2004 | 07:13 AM
MINImotor's Avatar
MINImotor
Germans know better....
Gives you the ability to dial in your setup- 18mm, 19mm (standard hole) and 21mm (effective using second hole). For reference 17mm is stock.
I'm actually going to run the stock front bar with the 18mm rear for a mild upgrade with a little more rear bias. This should help rotate the rear. Otherwise a sticky set of r-compounds are all that is required for a corner demon.
Old Dec 23, 2004 | 07:26 AM
scobib's Avatar
scobib
I've found that I need my H&R 19mm rear bar set on the firm setting to get the rear end to rotate like I want it... I have H&R springs, too, and the stock front swaybar.
If you install the H&R front swaybar, you'll definitely need the 19mm to make the car neutral... I like H&R's matched system, though.
Old Dec 24, 2004 | 06:59 PM
Ryephile's Avatar
Ryephile
I still have no idea why H&R chose a 27mm effective front bar, it's too stiff. The H-Sport 26mm effective front bar is already bordering on too much. This 3 for 2 deal doesn't sound like anything useful to me, as you'll never use the 18mm rear.
Mini7
Feb 2, 2016 07:52 PM
minimofo
Sep 9, 2015 10:29 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
