Suspension Rear Sway Bar Install
On my 2019 F56 I didn't need to drop the exhaust at all. There is one bolt on a heat shield that needed removed so the heat shield would move when you loosen the rear sub frame. The four bolts that hold the sub frame are easy to get to and the things sags down a few inches on its own giving you the clearance to pull the bar. Use your own judgement since I'm not an expert, but I just did it.
You don't "DROP" the subframe.
Look here:
http://www.nm-eng.com/media/attachme..._NM.258846.pdf
Enjoy!!
Vendor
I don't drop the exhaust. But I do take both rear shocks loose, then take the springs out. After that I pull the subframe bolts and pry it down to get the sway bar bracket bolts and pull it out.
Here is our bar we use for installs.
https://www.waymotorworks.com/wmw-25...5-f56-f57.html
djslipstream
04-23-2019 05:21 AM
silviahrc
R55 :: Clubman Talk (2008+)
03-31-2017 06:41 AM
silviahrc
R60 :: Countryman Talk (2010-2015)
03-23-2017 06:27 PM
