Suspension BC Racing for F56 BR Type RA with camber plates
#26
Hi Gardus, this is my 1st post on the forum after finding your BC coilover install
I have a couple of questions the 1st being : Could you tell me how you went about coding the DDC as I would like to do this as the KW DDC delete kit here in the UK costs over £350?
2nd question : You say you have supplied does this mean you have this set available? I have contacted a few dealers here in UK but cannot get the exact kit
Cheers for any info
Cheers for any info
#27
I'm not Gardus, but I did recently install the same coil overs on my F56 to replace my OEM Sport Suspension W/NM springs.
If you install coil overs, regardless of the brand, you will lose the DDC function. The kits listed as comparable with DDC just include a plug in to spoof the car into thinking everything is fine with the DDC system. Doesn't cause a problem, but is a waste of an expensive OEM option.
No idea on your second question. You might try to contact Gardus via PM though.
#28
Not worried about losing the function really, I was thinking about springs but I don't want to stress the OEM's and also could not get as low as I wanted.
Cheers
#29
#31
I fitted and sold quite a few and they're ok.
https://silverproject.eu/product/cam...i-f55-f56-f57/
Pay attention to not get the ones for coilovers, as those are for suspension with a independent upper spring perch and won't work with the B14 PSS.
If you have trouble getting them in your country let me know.
Darbys2019MiniJCW (05-16-2019)
#32
You can use the Silver Project camber plates, they are made to work with the stock suspensions or any suspension kit compatible with the OEM top mounts.
#33
If you are in Texas I would look at Vorshlag. They make them for our cars and sell them to WMW.
Link to WMW
Link to WMW
#34
#35
Link to WMW
Link to WMW
#36
https://www.northamericanmotoring.co...ml#post4446361
After not checking in for awhile it's awesome that there's finally camber plate options, Vorshlag finally stepped up, Silver, K-Mac, much better than a few years ago when your options were buying a 'clubsport' coilover and BC's were still on the horizon.
