Suspension Are front camber plates REQUIRED for coilover install?
Old 06-22-2017, 08:01 AM
njaremka's Avatar
njaremka
njaremka is offline
Alliance Member
Received 1,714 Likes on 1,381 Posts
I recently purchased a set of H&R RSS coilovers for my Clubman, and I'm starting to lay out my install and collect additional parts required for the swap over.
I know I'm going to want rear camber arms, so those are part of my budget already. I'm also planning on FatCat rear bump stops, and poly upper mount bushings.
One lagging question I have relates to the front upper mount. Do I "NEED" to replace the strut mount with a camber adjustable mount, or can I just through an OEM mount in there and call it done? I know the front doesn't gain as much camber when lowering as does the rear, which is why I'm asking the question.
My goals with with the installation are for a lowered ride height, increased street handling, and daily highway travel.
Old 06-22-2017, 08:39 PM
squawSkiBum's Avatar
squawSkiBum
squawSkiBum is offline
Moderator
not required, but I highly recommend it. 1) You're already doing all the labor to remove and re-install the shocks. 2) with a set of camber plates you don't have to swap the top mounts over, if you were already planning to buy a new set then look at the incremental cost for camber plates. 3) You have to get an alignment afterwards no matter what so make the most of it. 4) getting to about -2 degrees front camber makes an amazing difference in handling. 5) if you don't track or autocross the car, then you can ignore everything I just said and go with the OEM top mount, pull the plastic pin, and ask the aligmnent shop to max out the front camber.
Old 06-23-2017, 03:17 AM
njaremka's Avatar
njaremka
njaremka is offline
Alliance Member
Thanks for the feedback.
The biggest problem I'm having with adjustable strut mounts is justifying the cost. Quality aftermarket replacement mounts can be had for ~$30 each, and the least expensive adjustable mounts are ~$150 from eBay. (And who knows what kind of quality those are)
Thus my conundrum... I will be replacing the mounts regardless if I get OEM replacements or adjustable ones. I guess I just have to figure out if I want to spend the money or not...
Old 06-23-2017, 07:25 AM
mashby's Avatar
mashby
mashby is offline
njaremka -- just posting to follow this thread.
I'm thinking of doing the same thing for my R55 down the road, so please keep us updated with how it goes!
Old 06-27-2017, 06:17 PM
mbwicz's Avatar
mbwicz
mbwicz is offline
Another option are the Ireland Engineering fixed mounts. They are factory strut mounts that are put on a plate that adds additional camber. So they maintain the factory ride quality and durabilty for about $200. They aren't adjustable like the nice ones. I put 50k on a set on my old car and have a set ready to go on my 2013. With these I was able to get about -2.0 camber in the front, and I agree with the above comment that they made a really nice difference.
Have fun,
Mike
Old 07-28-2017, 12:34 PM
gbuff1's Avatar
gbuff1
gbuff1 is offline
Have fun,
Mike
The IE site states these are to be used with stock springs, which I have....wonder if they raise the ride height?
