Suspension Megan Racing Euro 2 Coilover Review
#27
That's strange. I had ST coilovers on my JCW, lowered at least 1.5", probably more. I didn't need front end links or anything in the rear.
EDIT: After more research, I just bought ALTA front and rear endlinks, and Hotchkis lower control arms. You don't NEED them, but it could probably explain the extreme rear camber and unpredictable oversteer I had with the JCW.
#28
anyone have any issues with (aftermarket) rims being real close to the front coilover? NMs are et45, i threw a 5mm spacer up front but you can still see a slight bit of rubbing by the rim guard of the tire.
would it be best/acceptable to adjust the stock concentric nut to push the spindle as far away from coil over and then use the camber plate to set the camber?
#29
SkyLynx
03-14-2016 08:20 AM
TheBluePotato
59
05-03-2003 09:59 AM
pymx
09-25-2002 01:35 PM
