Koni FSD R53 to R56
hi just want to ask if i can use the koni fsd of my r53 to my friends r56? im using koni fsd with jcw springs. I got a set of KW V1 from r56 and i was able to use it with my r53 just swapped my IE Fixed Camber Plates in the front and removed spacer/washer in the rear where you put the bolt.
My friend would like to try if the koni fsd/jcw spring will fit his r56 if we put the r56 top mount and the washer/spacer at the rear. thanks |
