Suspension Anyone try the "big pair" chasis braces?
Never read a post about this, but a bunch of people put in the strut brace thingy that goes under the hood and I never heard that anyone was impressed with that. This looks a little more substantial. The Roadster (convertable) and Coupe supposedly have stiffer chassis/frames than the R56 but I have no idea what the diff is.
I love jacking up the front to put the jackstand under the rear support point!
I thought about these too but hell mines so stiff when I go in at angle to a inclined drive way one of my rear wheels leaves the ground. Is your suspension stock otherwise ?
To put it in perspective, the wheel rate of a stock MINI is about 4.5 NM/inch, and an R53's chassis torsional rigidity is 24,500 NM/degree. You'd have to essentially run your car into curbing at speed to flex the chassis measurably.
To put it in perspective, the MINI's chassis rigidity is similar to a last-gen Mercedes-Benz S-class [W221]. The reasons you don't hear the chassis flex in an M-B are two-fold. 1) they spend many more development dollars ensuring exactly that; all the plastics and contacting materials use rub-tape or felt so they don't produce a noise even with the very small displacements they see, and 2) the suspension tuning is much softer than the MINI, so more motion and energy is absorbed by the suspension and not transmitted into body structure, where your seat is directly bolted. Drive a Mk5 or Mk6 VW GTI, however, and you "hear" a bunch of chassis flex, though in reality the rigidity is also on-par with the MINI. Perception can be very different from measured reality.
I'm referring to the all the MINI's, however only the R53 was released with an exact body rigidity number within the press release. Every successive MINI generation has been referred to as "stiffer" without any disclosed numbers to go along with that assertion. BMW's rather hit-n-miss on this particular metric.
Tires, Wheels & Brakes
10-01-2015 02:22 PM
10-01-2015 12:18 PM
10-01-2015 10:38 AM
10-01-2015 10:17 AM
