Suspension Raising (yes, really) my R53. I need advice!
Old Mar 17, 2013 | 11:15 PM
lizzflowers's Avatar
lizzflowers
Hi everyone,
I moved to California and the roads to and from my work and school are really bad. My car is only a few inches off the ground as it is due to lowering 5+ years ago, but additionally the suspension is pretty shot. I don't remember what is on there now, but I would really like to raise my mini like the Dsquared "HIV fundraising" mini cooper. (Google...) They raised the Chassis and put all season deep thread tires on it. However, I haven't found a mini modder near me. So, to the point: I need someone to give me some advise on what parts I should order, some do's/don'ts, and any other information you think would be helpful so that when I go into the shop I know what to ask for. I want to do it correctly so that my car can take the rough roads and ridiculous miles I have been putting on it with less wear and tear. I'm willing to put the money and time into it, I really want my car to live forever! (Tee hee). I would be very grateful for any advice! Thanks so much
Old Mar 20, 2013 | 01:14 PM
andyroo's Avatar
andyroo
Do you want it to be tall or do you want it to ride well?
Getting it above stock ride height requires some custom fabrication that may be pretty simple but just might not be necessary.
To get it to ride well, get Koni FSDs, stock springs, and non-runflat tires. Replace your strut top mounts and front control arm bushings if they are old and crusty, which they probably are.
This will ride better than stock, and probably handle better than your lowered car that has no bump travel.
- Andrew
Old Mar 20, 2013 | 03:53 PM
daflake's Avatar
daflake
Stock springs and FSDs will actually raise it just a little over stock. It will also provide a better ride and better handling as well.
I second the recommendation.
Old Mar 20, 2013 | 08:55 PM
bmwr606's Avatar
bmwr606
coopercrap.com has 2" lift kits fot r60 and r55/r56
maybe they can help
http://coopercrap.com/r5655-lift-kit/
scott
Old Mar 21, 2013 | 07:39 AM
andyroo's Avatar
andyroo
Those don't add any bump travel though, so they won't improve ride quality. You just get clearance.
- Andrew
Old Mar 21, 2013 | 07:50 AM
bmwr606's Avatar
bmwr606
- Andrew
true, but OP said he wanted BIG tires and the lift kit will allow big tires
scott
Old Mar 21, 2013 | 07:51 AM
andyroo's Avatar
andyroo
true!
Old Mar 21, 2013 | 12:34 PM
lizzflowers
Y'all are the best. I will let you know how it goes! Thank you so much!
M7Speed
Jul 10, 2018 09:26 AM
rikaro
Nov 24, 2015 02:05 PM
zdw2082
Oct 5, 2015 09:59 AM
M7Speed
R61 :: Paceman Talk
Oct 1, 2015 06:57 AM
nshannon29
Sep 30, 2015 05:21 PM
