Suspension mini cooper S 03 r53 which springs h&r or Tein?
Old Jan 31, 2012 | 06:55 AM
oscarjob8's Avatar
oscarjob8
whats up everyone im having an issue on deciding which lowering springs i should get... read a lot but still really havent had an answer from someone that actually has them on.. i want to ride on stock struts just want to buy springs.. i read that h&rs were good and also Teins... i got a mcs r53... HELPPP... lol i want a smooth ride tho not like bouncy or too stiff....
Old Jan 31, 2012 | 07:28 AM
quikmni's Avatar
quikmni
I had H&R on my 2003 MCS with stock shocks. The amount of lowering was good and the ride was good (similar to stock). You will want to purchase adjustable rear lower control arms to reduce the amount of negative camber in the rear created by lowering, otherwise your tires will wear too fast on the inside edge.
Old Jan 31, 2012 | 07:41 AM
oscarjob8's Avatar
oscarjob8
Oh ok awesome. What brand of control arm did u buy? Would I have to also buy for the front as well?
Old Jan 31, 2012 | 08:19 AM
Helix13mini's Avatar
Helix13mini
H&Rs are excellent, and lower control arms will allow you to dial in your alignment correctly. Check Here:
http://www.helix13.com/1st-gen-mini/...suspension/#go
Old Jan 31, 2012 | 05:52 PM
quikmni's Avatar
quikmni
I used the H-Sport Adjustable Rear Lower Control Arms.
You do not need adjustable lower control arms for the front. The front camber will not change (at least not much) with lowering.
Old Jan 31, 2012 | 06:57 PM
oscarjob8's Avatar
oscarjob8
Ok very helpfull now I'm also looking for an intake but can't decide Alta good?
I come from a VDUB lol dont know much about minis but now love them <3
Old Jan 31, 2012 | 07:52 PM
miniblucabrio's Avatar
miniblucabrio
The Alta intake is decent- makes plenty of noise ie supercharger whine The JCW intake is better for a power increase. Any open top intake is going to suck in hot air from the engine. One with a top on it will help to minimize that hot air.
I see your in Jersey. check out http://nemini.org we are an active local group. Hope to see you out on a run sometime
Old Jan 31, 2012 | 08:17 PM
oscarjob8's Avatar
oscarjob8
Alright thanks I look into the jcw intake... And that sounds great really wanted to join a crew helps a lot in every way.. I signed up at that website.. How often you guys meet and where in jersey?
Old Jan 31, 2012 | 08:33 PM
miniblucabrio
Things are kinda quiet in the winter but spring through fall are quite active. The runs happen all over the place from NJ to CT. keep an eye on the meets rallies and runs section for upcoming events. I know there is one coming up in Feb on Long Island. there was also a weekly meet up in Jersey. you might know it. I believe it was mainly a VW meet but a mix of cars showed including a couple minis. even a classic mini made it once or twice.
Old Jan 31, 2012 | 08:52 PM
oscarjob8's Avatar
oscarjob8
Yeah the weekly one up north jersey.. I had an mkIV gli.. But I will deff keep an eye open for the runs and meets around here... By the way where's the runs n meets section at?
Old Jan 31, 2012 | 08:56 PM
miniblucabrio
When you sign in there it's on the first page down a little ways. look for the header Meets Rallys Runs
Old Feb 1, 2012 | 02:57 AM
NightFlyR's Avatar
NightFlyR
Also look on the NEMINI boards, Nj is very active even in the winter months.
Old Mar 13, 2013 | 05:53 AM
HYDE16's Avatar
HYDE16
I believe you are referring to the Garden State Euros weekly meets at the Lowes of Butler, NJ. March 20th is their Spring opener meet.
Old Mar 13, 2013 | 06:21 AM
HYDE16's Avatar
HYDE16
Here is the Spring Opener thread:
https://www.northamericanmotoring.co...th-2013-a.html
iggi
18
Feb 9, 2026 01:00 AM
andrewjg1994
Jan 29, 2021 07:45 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
