Suspension BC Coilovers RM Series - anyone used them?
i've seen a lot of good reviews of the br series of bc coilovers on the mini....but what about the RM series-they're both about the same price but are supposed to be a beter spec, anyone used them? links below for reference.
http://www.larkspeed.com/index.pl?p=BCRMT01MH&a=i
http://www.larkspeed.com/index.pl?p=BCBRT01RA&a=i
From the provided write-up the RM series looks like a good deal. The spring rates appear to be the same. The shocks even appear to be similar except the RM has the advantage of being inverted. Also the RM appears to come with front adjustable camber plates.
The advantage of inverted front struts basically comes down to slightly less unsprung weight, slightly less shock fade on longer track sessions, and the strut is a slightly stronger and can handle side loads better.
Bilstein, Ohlins, some AST models, all use this feature. It's not a "must have" IMO, but sorta nice.
Quality of the valving is the #1 most important feature for any suspension, along with total suspension travel (depending on your chosen spring rates).
- Andrew
- Andrew
sssevita
Mar 20, 2016 06:24 AM
